View Single Post
Old 03-18-2019, 03:11 AM   #2
Originally Posted by LeonardoDaVinny View Post
So I was taking apart the car for a wrap and removed the driver's door handle. After putting it back together, I noticed that the handle only pulls straight out and has no rebound/tension (does not open the door).
This is the handle from the outside. It just stays pulled out after tugging on it. Has anybody had experience with this and if so, how did you fix it. Thanks!
I reckon there is a spring that pulls the handle back in - that you left out on the rebuild -
I suggest you take apart the other sides handle, see what it has that your busted side does not have - and order one of those.
OR, look around closer on the garage floor - hint, it will be further away than you would think it would be -
OR go to
https://demos.starbase7.net/t3Portal..._rm_index.html
(see the reassemble part for the front door handle)
