View Single Post
Old 08-02-2017, 03:54 PM   #13
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
See if you can get a big empty parking lot with consistent, fairly fresh asphalt and try both left and right hand turns. Bring a passenger along to see if it's truly repeatable. Snap the wheel 1/8 turn each time, then 1/4 turn and see if both times it was identical.
I think the previous posters are onto something with either inconsistent turns, passenger weight, or a super screwy alignment.
Have you had the car aligned? Has it always done this or is this new behavior? (Or is the car new to you?)
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
strat61caster (08-02-2017)
