Originally Posted by guybo
Have you actually stuck your own head under there and poked around? Check to see if any of the dampers are leaking badly, eyeball everything and see if anything is bent. Don't assume the tech at the dealership looked and/or gives 2 shits. Grab and shake everything. It's possible it's not the LR even though it feels that way. If the RF damper is blown in bump and you take a hard left turn, the car's weight transfer may completely unload the LR making it feel like that corner has the issue. Same if the roll bar is not connected correctly of the bushing is completely screwed.
this sounds very hardware to me
Has to be hardware! Hopefully soon it gets resolved. Really not wanting to trade her in as it'd be cheaper to just fix this one.
