View Single Post
Old 04-21-2016, 04:46 PM   #508
strmshadow84
Drives: 14 Cayman S, 16 Camaro 2SS
Originally Posted by BRZoomTX View Post
AC can easily be re-done via custom AC lines using the OEM condenser. Only problem there is the time and cost of making the lines. You can use rubber lines but they wont bend around tight turns, need hard lines for those areas.
Once more people swap, more demand for working AC will be there and I'm sure Vorshlag could consider making something if they don't have plans to do so already.
There's more to getting working AC then just lines, if your gonna use the OEM condenser (prbly a bad idea, the rx7 ls swaps had a few of them burn out) you still need to use the ecu to control when the clutch engages. More than likely it will be using the chevy condenser which still needs to talk to the gm ecu (you could pbly do it the same the rx7 guys do).
strmshadow84 is offline
