Originally Posted by stokeless
I had this clinking/cranking sound when turning the last few days, I did some research and it could be my pillowball (isc coilovers) mounts or endlinks... I drove the car out of the garage this morning and heard the noise when turning but while driving in the rain, after several mins it went away.... I have about 800 miles on the setup. I will jack the car up later to inspect but have you guys had or heard of this issue?
Definitely a suspension component.
Check:
-ball joints
-the upper strut bearings for play(this might be the pillow ball)
-make sure the top nut on the coil over is tight(I found this to be the issue on my buddy club n+ coilovers once)
-endlinks
Hate to think it would be a wheel bearing issue with such low mileage. Im at least assuming it's relatively low mileage for such a new car.
Just some thoughts off the top of my head. Good luck with your dx process
