Originally Posted by benlaz88
So, i just adjust my clutch pedal today and put it to the same position as my brake and its feel so much better. Pedal are lower and no need to push gas to roll forward and reverse. Didn't smell any burnt for 20 mile ride, shifting are good, and no grinding while shifting to all gears. Seem like there are no problem so far.
Is there any other things i should be noticing or be aware of while testing the adjustment?
If there is just a hair of free play at the bottom of the pedal, you should be OK. That being said, you'll notice your pedal has much less resistance to being pushed in now. Remove that helper spring attached to the clutch pedal and enjoy!
