View Single Post
Old 11-23-2013, 07:07 PM   #2599
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Gary in NJ View Post
Yeah, think of it more as heal and SMALL toe(s). In reality it's the top right side of your foot that you want on the throttle. Your foot should be tilted about 30 degrees to the right from vertical. Once you get the right coverage, the "feel" that you'll have to learn is how to blip the throttle without adding pressure to the brake pedal.
The other technique that I use quite a bit is clutchless shifting. Once you get the feel for it, it's as easy to down shift as up shift. As I think about it...I probably use this technique more then heal-n-toe.
Since this is off-topic, feel free to ask for more details via PM.
FWIW, I heel-toe with my foot rotated counterclockwise with the heel blipping the throttle and the toes on the brake. This is because it is easier to finely regulate brake pedal force with the toes since you actuate with ankle muscle, not quadriceps. It's definitely more awkward at first but better in the long run. FWIW, I used to do it the way you describe when I first started heel-toe'ing 20 years ago. It seems easier to learn at first but the other way is better for sure.
Just my 2c,
Shiv
ps. See you Monday Sojhinn!
Shiv@Openflash is offline   Reply With Quote
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
asher187 (11-23-2013), Sojhinn (11-23-2013)
