Originally Posted by FRSRAVEN
Possibly increased belt wear or the belt coming off the pulley. Perhaps some increased bearing wear on the hub assembly itself due to balance issues. But the question becomes.
Is the .4mm of runout reported by diss7 enough to cause these issues? I don't know.
You have to remember, that the 0.4mm on the a ~25mm hub would then be 3x as bad on a ~70mm pulley
You can see what it looks like in the video I linked to in my build thread. You don't want the pulley 0.1mm on the piss, let alone 1.5mm.
Re serial numbers, posted pics of both up.
