View Single Post
Old 09-06-2013, 10:21 AM   #108
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Originally Posted by fatoni View Post
im a huge miata fan but i understand they are pretty heavily handcuffed from the factory. however, saying no built miata can keep up is ridiculous.
my bad then. i usually dont go by msrps so i didnt even check. in my neck of the woods, you arent going to find one in the five figure range.
Apples to apples. You modify the Miata (which is not building one, btw, only car manufacturers build cars with their brand name on them) then you modify the Cayman in the same way. Cayman beats Miata every time, no matter what you do.
The Cayman can easily be modified to outperform the 911. Several people have just swapped in a 911 engine and la voila.
I'm pretty sure a factory Cayman is a better handling car than any Lotus currently built
Suberman is offline   Reply With Quote
