can I buy the resistors off from you? :) |
If he can't help you out you can buy them here. http://www.frsport.com/Splash-SB-Har..._p_281671.html Sent from my iPhone using Tapatalk |
Thanks ZOMFGAARON I think this is the correct one http://www.frsport.com/Works-Bell-10...r_p_59074.html http://www.evasivemotorsports.com/mm...Code=WB-OPTION |
I use the one linked for both connections with no issue. Sent from my iPhone using Tapatalk |
So I have both the SRK-125H and SRK-120H... I want the 120H bc it's a lot shorter and my wheel sits really close to me...
If i remove the clock spring, does that just make the lights on the dash pop up? because I have the 86nanny which turns off my traction and abs... plus it doesn't bother me since my cluster is in my glove box |
| All times are GMT -4. The time now is 12:20 PM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
