-   -   Which tires? (https://www.ft86club.com/forums/showthread.php?t=98578)
Eighty 6 12-07-2015 11:55 AM
Which tires?
Hello everyone, just bought a 2013 gt86 and it needs tires "badly" what would you recommend for "all rounders" and something that I wouldn't have to sell a kidney for. Thanks in advance. I also need to do a bit of maintenance on it "cheaply" I guess change oil, spark plugs and filters.
go_a_way1 12-07-2015 11:57 AM
:popcorn:
Atticus808 12-07-2015 12:09 PM
Check out TireRack
There's also a sub form on here with plenty of info (check out the stickies)
http://www.ft86club.com/forums/forumdisplay.php?f=24
Eighty 6 12-07-2015 12:23 PM
Thanks Atticus, that link is massive. I was looking at the original 16 inch Micheline's but peeps were complaining about them, I prefer Pirelli but turns out I'd have to sell a lung, what about Yokohama anyone try those?
D_Thissen 12-07-2015 12:26 PM
How many km are on your car? You should have to change the spark plugs yet. As for an oil change, any 0w20 should work fine with an OEM oil filter.
go_a_way1 12-07-2015 12:27 PM
To give you some real advise look into Nitto Invos. I run those and they are a great all around tire. You have to get them in 225/45R 17
NOHOME 12-07-2015 12:33 PM
Good reason to change them is "because you can".
With the high mileage that people get out of plugs, its not uncommon to have plugs that refuse to come out of an aluminum head when people do get around to changing them. With the way the boxer is packaged, it would be an engine out job at minimum.
Eighty 6 12-07-2015 12:34 PM
35k on it, 0w20 5 liters, oil filter on top with these cars, too easy.
Eighty 6 12-07-2015 12:36 PM
Thanks, the ones I have now are 16 inch, do you think I can fit 17 inch on the same rims? ( sorry for the dumb questions but bear with me)
go_a_way1 12-07-2015 12:38 PM
Nope. And the smallest size you can get is the 225/45R/17 for those tires so I guess they are out. You should buy some 17inch OEM rims, lota people sell them cheap and they even come with rubber most of the time.
Eighty 6 12-07-2015 12:38 PM
Jesus... Engine job to remove sparks? Only if they stuck tho right? It has 35k, but previous owner did a bit of drifting with it.
LOLS2K 12-07-2015 12:40 PM
:popcorn: Good read...
Eighty 6 12-07-2015 12:41 PM
Thanks for the advice. This is one helpful site.
jawn 12-07-2015 12:44 PM
He's clearly in Europe or Asia, so I don't know if buying the OEM 17s will be cheap for him. 16s are OEM for a lot of GT86s.
