-   -   toyota quick shifter? have you tried it? (https://www.ft86club.com/forums/showthread.php?t=96473)
Lord09 10-21-2015 12:46 AM
I'm surprised you experienced such poor fitment, mine fit perfectly and when tightened it was perfectly flush. It is a bit of a pain to get a wrench in there, make sure you get a ball end 7mm hex socket and torque it to spec and use blue loctite per the instructions and recommendations on the forums.
Even though the torque spec is only 7 ft/lbs, I was surprised it took so much force, if I did it w/o a torque wrench, I doubt I would have torqued it to spec.
Ultramaroon 10-21-2015 01:04 AM
It was cocked to at least 10 degrees before I started grinding. Inexcusable.
