-   Suspension | Chassis | Brakes -- Sponsored by 949 Racing (https://www.ft86club.com/forums/forumdisplay.php?f=59)
-   -   Bilstein B6 or B8? (https://www.ft86club.com/forums/showthread.php?t=96118)
smg1138 10-12-2015 02:42 PM
Bilstein B6 or B8?
So, I'm seriously considering upgrading to Bilstein dampers matched with some Swift Spec-R springs. Only thing is that I can't figure out which ones to go with. I've read some conflicting information about which is better for this amount of drop. The Spec-R's advertise a 28mm front and 25mm rear drop, but I've read that's actually conservative. I'm thinking the B8's would be best, but I'm still not 100% sure. Anybody have any experience with this that can offer some feedback?
PERRIN_Chris 10-14-2015 06:33 PM
Check with @FT-86 SpeedFactory. They've ran both of them before and will be able to give you the best advice.
FT-86 SpeedFactory 10-15-2015 12:01 PM
Even with the Swift spring's modest lowering, you are still shortening the amount of stroke on the piston for the damper. The B8 does account for this and has a shorter stroke with a smaller internal bumpstop than the B6. They are also damped for higher spring rates of lowering springs.
That being said, I believe it would depend on what you are looking to do with the setup. If you are looking for more performance, the B8 will firm things up a bit more with the springs to ask a bit more from your tires. The B6 would be more comfortable over bumps with the longer stroke that is available. Most want a little of both as their cars are daily drivers, a bit of comfort with some more performance and go for the B6.
Hope that helps a little!
Cheers,
-Yo
_gt86_user 10-15-2015 03:18 PM
You can match those struts with the Swift sports too they ride pretty good for daily and firm things up quite a bit, I'm on OEM shocks at the moment but I feel there is still enough stroke to soak up the bumps.
smg1138 10-15-2015 04:34 PM
I do Autocross, so the Swift Sports would be too soft. Right now I'm using RCE Yellow's on the stock dampers and it's been ok but not great. I thought the B8's with the Swift Spec-R's would be a good setup for STX without having to deal with the headache that comes with adjustable coilovers. It may just be wishful thinking on my part though. :)
Ro_Ja 10-15-2015 05:31 PM
Cheers,
-Yo
But the valving is the same between the two?
http://www.ft86club.com/forums/showp...9&postcount=60
