Is Paint Sealant better or worse than Car Wax?
I've started using Griot's Garage One-Step Sealant [ame="http://www.amazon.com/Griots-Garage-11075-One-Step-Sealant/dp/B002E02MOQ/ref=bdl_pop_ttl_B002E02MOQ"]Amazon.com: Griot's Garage 11075 One-Step Sealant - 16 oz.: Automotive[/ame].
I like it a lot but am unsure about the differences between a paint sealant and a car wax. Is using a paint sealant better or worse than using a car wax? How is a paint sealant different from a car wax or are they basically the same thing? Can I use a paint sealant THEN a car wax? |
in short terms
sealant is what protects the car Wax is what gives it that glossy wet look |
The difference between a wax and a sealant is longevity and ease of use. It has NOTHING to do with what the car will look like when either product is applied. A sealant is longer lasting but takes a lot longer to apply (curing time), giving it a level of difficulty. A wax is a LOT easier and quicker to apply but does not last as long. Those are the simple facts. It's not a case of which is better, it's a case of which is more convenient to you due to the application process. You have to make that call. |
In fact the car looked great aftewards. |
A one-step wax or AIO (all-in-one) is a product that is supposed to correct and protect in one application. Thus, it contains the correcting ability of a light polish and the protecting ability of a wax. It does neither very well and is normally used when you don't want to take the time to separate the process out, which is the preferred way to do this in order to get the best results. A lot of detailers will use products like this to speed up the process of fixing cars so that they can get them in and out the shop quickly in order to maximize their profits.
I admit, claying with traditional clay will wear a ball and socket joint out in your arms if you are as old as me but I did a recent video on 3 different types of claying medium (the claybar, claying towel and clay eraser), and after it was all said and done, the clay eraser was a winner. MUCH eraser on these old joints. You have to really use clay to appreciate what it does for the final outcome. As much as I hate the work, I won't do anything without it if the necessity is there.
The polish in that product is so light that I'm positive he's not doing any damage with it. The only thing that polish is going to remove is VERY light damage anyway.
Btw, claying isn't that difficult if you are using a lubricating spray. Its actually pretty easy, easier than buffing out car wax/sealant. |
Take your car to a detailer to get Opti Coat Pro applied. Best $395.00 spent on my car. Ease of washing car and I wax with Optimum Spray Wax once a month and use Optimum Instant Detailer Spray every other wash.
| All times are GMT -4. The time now is 11:56 AM. |
User Alert System provided by
