Don't forget about the rare earth metals that makes it expensive and rather bad for the environment
Oh and just because you said not too: http://vignette4.wikia.nocookie.net/...20111206025956 |
electric, but only after battery tech evolves into something a little more practical as far as weight and distance per charge goes.
I'm not sure what you mean by CPUs are limited by silicon, and I design CPUs for a living. The problem with supercaps and batteries is that they simply don't have the energy density of gasoline. Gasoline: 44MJ/kg Li battery: 1.8MJ/kg Super cap: 0.018 MJ/kg The numbers above are from Wiki, so they may not be gospel, but you get the idea. If you want to be able to drive your car even moderate distances, you'll need a huge ass battery. |
There has only been incremental improvement in battery energy density over the last several decades. |
One thing I like about driving my car is the feel and sound of pistons thumping inside that engine block which you can never get from electric or hydrogen power plants. So, I will always prefer gas engine.
But, that being said, we built Formula SAE electric car when I was in univ and that thing was a rocket....sooo much torque!!! But power source was an issue as you can only run the car for so much before its out of juice. So, if in the neat future, we can figure out better power source, I may consider electric power plant....maybe a small nuclear reactor...lol!! |
If I'm wrong feel free to correct me. Main reason why I made this thread was cause I just wanna learn :thumbup: |
Electrically Supercharged!
Added cost - ~$2k Added weight - None Added power - lots Added torque - OMG Improved fuel economy - who cares! https://lh3.googleusercontent.com/tu...w2200-h1238-no [ame="https://www.youtube.com/watch?v=C83mb-BI8ZM"] 1 [/ame] |
The issue that they were trying to highlight is that they are exceeding the thermal budget for the intended application. It's not an inherent limitation of the silicon. If you have enough money to provide the required cooling, the silicon will run very, very fast. The problem is most people aren't willing to pay for that extra performance. Like every other engineering problem, it's a trade-off. Getting back on topic, just like electric cars. Yes, you can power them with batteries or caps, but just don't expect to go very far. Or very fast for very long. The most efficient options are things like the i8 or Porsche 918. A gasoline power plant that can run at maximum efficiency which provides power to an electrical engine. You can use caps/batteries to store energy and act as a buffer or power smoother so that the gasoline engine runs efficiently. |
| All times are GMT -4. The time now is 07:41 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
