-   Issues | Warranty | Recalls / TSB (https://www.ft86club.com/forums/forumdisplay.php?f=72)
-   -   CLUTCH LAG (https://www.ft86club.com/forums/showthread.php?t=94977)
STV3 09-17-2015 06:02 PM
Originally Posted by babydriver (Post 2393447)
If you haven't yet done so, this thread will tell you how to adjust your clutch pedal:
http://www.ft86club.com/forums/showthread.php?t=8040
If properly adjusted, the clutch pedal need not go all the way to the floor; it merely needs to go to the point where the clutch is completely disengaged. To be absolutely safe, you can press it to the floor, but (for example) it is not necessary in my car to do this.
Almost anyone that adjusts the clutch pedal is doing so to make the engagement point lower. Meaning that it is even more important to fully depress the clutch pedal to the floor.
Please don't encourage the OP or anyone for that matter to not fully press the clutch pedal down when changing gears. Especially with the OP being new to a standard gear box.
jawn 09-17-2015 06:19 PM
This.
Koa 09-17-2015 06:26 PM
Please, bro.
Let's not be ****holders here. It's perfectly acceptable to tell a newbie the reality of the situation.
STV3 09-17-2015 06:36 PM
Originally Posted by Koa (Post 2393512)
Please, bro.
Newbie or not.... Unless you're drag racing and trying to cut .05 seconds off your ET, there is no reason to not push the clutch pedal to the floor.
Plus our clutch pedals are so light that it takes little to no effort to push them to the floor.
Koa 09-17-2015 06:55 PM
It doesn't help the guy understand what's going on in there by omitting the info the dude was trying to explain.
It's obvious the OP does his homework and has a vested interest in knowing what's going on.
Therefore, your advice isn't very sound and that's specifically what I am underlining here. Let's let the dude fuck his clutch up a tiny bit faster than MBT, as long as he learns more from it, what's the big deal? He'll be more in tune with what is ACTUALLY going on. I've taught scores of people how to drive manual. I am one of the biggest advocates to this and I have a knack for teaching. I also don't accept pandering and political correctness- it's not the hardest concept of the world to figure out that the pedal only actuates a slave cylinder with a very tactile on/off biting point.
Clutches and clutch assembly items are wear items. Don't forget that. :)
strat61caster 09-17-2015 07:04 PM
I agree with everyone else, take it easy, you're not going to win anything by being able to shift 0.1 seconds sooner at the risk of grinding a gear or having to manhandle the gearbox to get there.
I disagree with everyone else on this: you're not going to blow up your clutch/tranny by not pushing the pedal all the way to the floor, I often don't because I'm comfortable with where it engages and confident that I'm not damaging anything, no grinding of gears or difficulty getting in and out.
Practice experiment and good luck.
why? 09-17-2015 07:10 PM
um wait what? Since when is this reasonable advice? There is absolutely no reason to push the pedal further than it takes to completely disengage the clutch. If you cannot feel where that position truly is, then push the pedal to the floor. But seriously, only on some newer modern vehicles is it even remotely hard to tell where the clutch disengages.
Clipdat 09-17-2015 07:36 PM
Not sure if serious....
O.o
Toyarzee 09-17-2015 08:14 PM
Please master using your left foot before you concern yourself with extra footwork for your right... especially on public roads.
Whoever said fully depressing a clutch pedal is bad is about as stupid as the AAMCO rep telling me that it hurts the transmission to rest your hand on the shift knob.
Packofcrows 09-17-2015 08:34 PM
Originally Posted by carma143 (Post 2393334)
So you're saying I should press it all the way to the floor? I've had many people tell me that's bad for a clutch, especially when the clutch catches very high up, like in the BRZ....
Omg noob or Civic driver is blowing up in my head with that harmful to press full.
Clutch is meant to be pressed all in. Only times you dont is when you in uphill angle and nervous. In this case you balance car with clutch 1/2 and gas to prevent rollback action.
Youre new so feeling clutch lag is normal. Its issue with not balancing gas and clutch. Try it at 2k rpms and you wont feel lag. also, if you have issue with 2013, get ecu reflashed in case of rpm dip. Turn ac off until you l2drive.. engage clutch to gear in and out. If not, its like rubbing sand paper on clutch to force gear out. This can cause uneven wear and ruin your transmission eventually. But hey, its your car. If you burn clutch itll just be a quick $500 tops fix if you do yourself, or pay the mechanic $2500 if you know nothing of fixing clutches.
Maybe it needs clutch adjustment? I learned smooth shifting by driving from 1-3rd gear barefoot using just my toes. Try it out in safe area.
strat61caster 09-17-2015 09:25 PM
That was put out by the Car Talk guys many years ago, maybe plausible but not worth getting panties in a bunch.
http://community.cartalk.com/discuss...on-the-shifter
http://community.cartalk.com/discuss...-on-shift-knob
why? 09-17-2015 09:36 PM
O.o
Ah ya. Most cars you know exactly where the engagement point of the clutch is. Once the clutch is disengaged there is no reason to keep pressing it. It doesn't add safety or anything else. When the clutch is totally disengaged that is it, there is nothing else to do. That is literally what the clutch pedal is meant to do.
Now if you are a new driver, or are unsure, or just think it is a good idea, pushing the pedal to the floor will not harm the car, but it is never necessary and never has been.
Toyarzee 09-17-2015 10:18 PM
True that actually... http://www.ft86club.com/forums/showt...t=87082&page=2
But overall, i guess i should put that more accurately in the context of owning the car for a short term and already getting grinding.
A fun story: I brought my dad's truck into an AAMCO for a trans rebuild at his request. After i picked up the truck and drove straight to his house (less than 10 miles), there was fluid leaking. Brought it back and the first question the guy asked me was if i rested my hand on the shifter. I wanted to punch him in the face...
carma143 09-17-2015 11:53 PM
It happens about once a month to me and I probably shift gears 5000 times a month in the BRZ. If it is my fault, and in truth it probably is, I'm alright with it. It's not like I'm constantly hearing grinding sounds and screwing up my shifting :burnrubber:
Edit: Now that I remember I made a similar thread awhile back and some people also seemed to think I was screwing up my shifts alot even though I wrote it rarely happened. But as always, tips and general sharing of knowledge are greatly appreciated.
