http://www.motorsportreg.com/events/...5#.VXkPSflVhBd And I'll also be doing the Fall AROO day at PIR, no sign up yet, but will probably be the first or second week of October. |
Thanks for that. i will ccertainly run that day |
Sounds like they'll be running the short course in the afternoon, can't say I'm crazy about that as all the best corners are in the North loop.
Ho-ly-shit! The short course is freaking awesome! You sacrifice the half pipe for a straightishaway with a ton of short elevation change, car basically dances around underneath you the whoke time. Only two street cars there me and a C7, we were running a similar pace (which was way quicker than the majority of the field). Did about 2 hours on the full course and an hour on the short one.
Also, pretty sure I melted a throw out bearing :bs: |
In other news, sounds like I burned a new hole in the exhaust (need to get under to investigate) but I think I found a good oil balance. Couldn't get redline 5w30 with a setrab 16 row core to drop below about 60 psi (front of engine) or get higher than about 230F, and this was an 80 degree day and old oil (3 track days total on it) Also I'll have you know that tranny is an offensive term and you shouldn't use it. :lol: |
Once I save up for new front track pads, I'll join in on the track time again. Hopefully I get one more in before the season is over. Trying to finish paying off my debts by the end of the year (not counting house and car). I'll have more $ per month then unless I try to pay off my car quick next.
OK @Decay107 how did it go?
Also, I thought I'd dislike the sort course, but man was I wrong. Due to all the quick elevation change car basically dances right at the limit of grip through the entire bypass "straight" |
Just to let you know there is an event coming up at The Ridge on the fourth of July that's reasonably priced, $235. Most of the events there are $300>. The outfit putting it on is TSS/FFD. Registration is via Motorsportsreg. |
Yep, clockwise. Almost went up the hill after turn 5 right after they changed to the bypass, needed a real quick correction to not plow through the cones blocking off the northern part of the track. :lol:
And thanks for the info on the Ridge! I've been meaning to try it for a while, gotta see if I can fix the stuff I broke and still have some room in the budget to squeeze it in. |
| All times are GMT -4. The time now is 05:28 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
