-   -   Porsche Turbo Twist ET30 (et50-20) 18 x 7.5 (https://www.ft86club.com/forums/showthread.php?t=87029)
Tank 04-20-2015 02:30 PM
OE Porsche Turbo Twist in 18x7.5" et50 with 20mm adapters for +30 final offset.
Wheel weight is somewhere around 20lb.
Tires are 225/40/r18.
lowered with Bilstein coilovers. No extra camber and no rubbing.
http://i.imgur.com/yrkngoQl.jpg
http://i.imgur.com/3q9wrzyl.jpg
http://i.imgur.com/b6y77bzl.jpg
http://i.imgur.com/9ASHKktl.jpg
http://i.imgur.com/vuFQsoBl.jpg
nivek111070 04-20-2015 03:48 PM
not going to lie, looks hideous :|
Rapiddan45 04-20-2015 04:06 PM
Looks aside. Once it's lowered with a little camber I don't see there being any problem with rubbing, you can check out the wheel fitment guide though for that size/offset to make sure.
Pat 04-20-2015 04:06 PM
I kinda like 'em. Simple.
Tank 04-20-2015 04:08 PM
I wanted something different. And these will swap onto my other car as well. I like them at least.
nivek111070 04-20-2015 04:14 PM
that is actually all that counts "I like them at least." I hated them on my 911 lol
Pat 04-20-2015 04:18 PM
Heh...I had 'em on my 986 and loved how they looked on that car. I like 'em on 911s, too.
6-Shift 04-20-2015 05:16 PM
Get either camber bolts or coilovers with camber adjustment. With -2 camber, which is perfect for hard driving, you shouldn't have any issues.
Tank 05-04-2015 12:39 AM
Got all four wheels mounted, Pilot Sport A/S 3 up front, Bilstein coilovers. No rubbing!
Jive Turkey 05-04-2015 12:42 AM
i personally think it looks nice now, very clean. any reason for running different tires?
ditch those amber side markers
Tank 05-04-2015 12:45 AM
Thanks, I put the expensive grippy tires up front .
Tank 01-04-2017 04:04 PM
I still have the Porsche wheels on my FRS.
Might be time to switch it up though. Still haven't decided on what to get next.
http://i.imgur.com/Tcptf8I.jpg
http://i.imgur.com/FdbOrNh.jpg
burgeralert 05-10-2019 12:23 PM
Do you think these wheels with the spacers would have fit if you had just lowering springs and the stock struts? I know you have the Bilsteins but I am wondering if you had an 18x7.5 wheel with a +30 offset if it would work. Did it look like you had plenty of clearance at full lock?
Code Monkey 05-10-2019 12:27 PM
Looks great!
