-   Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) (https://www.ft86club.com/forums/forumdisplay.php?f=41)
-   -   Bendpak QuickJack BL-5000 (https://www.ft86club.com/forums/showthread.php?t=86627)
cnk 03-29-2016 02:05 AM
Originally Posted by zc06_kisstherain (Post 2600713)
@cnk, when you receive yours, did you have to unload it yourself to your driveway?
It's like 200 lb on wooden pallet and they'll charge extra if i dont have my own equipment to unload? i am thinking about purchasing 5000 soon
The delivery guy had a palet jack so I asked him to put it in my garage. He did it so I tipped him a $20. He wasn't supposed to, but I've found it's usually dependent upon the delivery guy.
For example, just had a 325lb treadmill delivered the other week. It was also supposed to be lift gate only at the bottom of my driveway. I asked the guy to put it in my garage for $20 cash and he did it.
If your delivery guy won't do it. They have to at least put it on your property which is usually the end of the driveway. You can then just cut the straps and carry the pieces one at a time. Heaviest is each jack which weighs around 80lbs. But it has wheels on one end so it's really not bad.
Sent from my SAMSUNG-SM-N910A using Tapatalk
zc06_kisstherain 03-29-2016 11:17 AM
Good to know. i was like shit..do i need to buy pallet jack?
thanks. i probably going to order 5000SLX next week
cnk 03-29-2016 02:35 PM
Yeah. . wish they had the longer one when I bought mine, but I guess that's what I get for being an early adopter. Works just fine though so I'm not worried.
You'll love it. . .I've had my BRZ, wife's Mazda3 hatch, a Mazda CX-5, and a Impreza wagon up with no issues. I'm a little safety conscious so I still put some jack stands underneath just in case.
Moving the jack piece by piece should be fine for 1 person. Moving that freaking treadmill with 2 people from my garage to my basement was a PITA though.
zc06_kisstherain 03-29-2016 02:42 PM
if i only have BRZ, i would get 3500 but i have SUV and minivan as well and tired of jacking up one by one for SUV and minivan. so, better to invest one for making my life easier.
safety is first. i always put floor jack on side + one tire of vehicle even it's on jack stands :)
Casey10s 04-01-2016 04:19 PM
Has anyone used any rubber pads that have slots for the pinch weld to fit into? I will probably order the 5000 version in the next few weeks.
zc06_kisstherain 04-06-2016 04:13 PM
I just placed order 5000. I will post when i get it
TRAKRAVN 04-06-2016 08:21 PM
Even with a standard jack I use hockey pucks with a groove cut in them. If the pinch weld is too tall for one puck I screw the two halves to a second pick underneath. They are small and fit in the spare tire well.
zc06_kisstherain 04-06-2016 11:17 PM
@cnk
I have another question.
when you need to put air in it, regular tire inflator is sufficient to fill 50psi?
since i dont have air compressor, thinking about to pick up $30-$40 tire inflator
aegisdrgn 04-06-2016 11:37 PM
Originally Posted by zc06_kisstherain (Post 2613076)
@cnk
Spend a little more and get this baby:
[ame="http://www.amazon.com/Viair-00088-88P-Portable-Compressor/dp/B005ASY23I"]Amazon.com: Viair 00088 88P Portable Air Compressor: Automotive[/ame]
I have it, pumps my tires up to 40psi on stock battery easily (within 30 seconds), then it slows down, but once the engine is running, it pumps super fast again (gotta get up to 50 for dorifto, yo)
cnk 04-07-2016 01:09 AM
@cnk
I used a bike pump. Only took a few pumps to get it up to 50psi. Didn't even bother to start up my 27 gallon compressor.
Sent from my SM-T700 using Tapatalk
zc06_kisstherain 04-07-2016 11:10 AM
thanks for the link. it's little out of my range but i will consider.
wow! didnt you know you can use muscle..haha
zc06_kisstherain 04-13-2016 10:16 AM
got tracking# so i should get it in my hand very soon!! yay!
zc06_kisstherain 04-18-2016 11:21 PM
got mine today and installed 5000 SLX
damm i followed 3 wraps on Teflon tape as instruction, and it leaked so bad..
i had retaped teflon tape all over again
here's some pictures and a video
http://i14.photobucket.com/albums/a3...ps31y1zuoj.jpg
http://i14.photobucket.com/albums/a3...ps2emiyvix.jpg
http://i14.photobucket.com/albums/a3...psjpyalwb0.jpg
http://i14.photobucket.com/albums/a3...pssgxveh7s.jpg
http://i14.photobucket.com/albums/a3...pscnq0wj0d.jpg
http://i14.photobucket.com/albums/a3...psw6vxbtd3.jpg
http://i14.photobucket.com/albums/a3...psq2vhuada.jpg
mine has little inclined driveway but didnt have problem since i used all 4 jack stands before.
http://i14.photobucket.com/albums/a3...psx0l3nrth.jpg
and here's quick video i took.
https://www.youtube.com/watch?v=ehRw...ature=youtu.be
i cannot use my garage because i have so many stuffs inside.
also it's not big enough that any car would fit in. (only miata barely fits lol)
no more jack and jack stands!!!
it will be much easier to work on my car as well as my SUV & Minivan
brzaapi 04-21-2016 09:10 AM
I am still between this and the EZ Car Lift. But one thing I really want from my portable at-home/track lift. Is the ability to place my RACE RAMP foam blocks under the wheels occasionally. Plus they would be great for extra protection incase of a lift failure.
But i need at least 12 inches of clearance beneath the tires to make this happen. It doesnt look like they would fit under your tire. Do you happen to know what the measurement is from the bottom dead center of your tires is to the ground when the car is fully lifted?
Here is a pick showing the Race Ramp foam blocks. They are 12(center) to 14(sides) inches tall.
http://www.ft86club.com/forums/attac...1&d=1461240616
