If you guys get a group buy going, I would be very interested. Located in Michigan though.
Me too
but tbh i dont want to break any rules here so i havent posted any in the tristate section for interests. i might just buy the one and be done with.. |
Damn I just saw this today, AND I'm in NJ... oh well.
I would be down for a groupbuy...
Quick jack 3500 support points
How does it support the factory jack points. Is it too short?
As was said earlier, the BL-5000 is 53 inches wide between the pads points. However, if you put the front pad on the front pinch weld and let the back one sit on the same rail, it works just fine and there has been no bending of the pinch welds using the rubber pads.
To address another point about the height and whether you can stack the pads to increase height, you can do it, but you have to wait until the jack is in place before you stack them. I usually only use the 3" pad as this provides plenty of clearance at the top position and there is no need for the extra 1.5". You have to remove these pads when not in use if you store the unit in the middle below your car. Otherwise, the pads will hit the exhaust as you drive forward and back (ask me how I know). This is a very handy device and I've gotten a lot of good out off it since I bought it last December. |
I have the 3500 version of this lift. I got it from flyin miata for around $900. The 3500 version, I've heard, is slated to go out of production.
I had enough clearance to drop the front subframe of my miata using the lift with the larger rubber blocks and lifting to the second safety lock point. It did take some effort to get the thing put together and working, but afterwards, it is a fantastic all around DIY lift system. I look forward to using it on my BRZ. |
assembly is quick? because i cannot use this in my garage. i have to use it on my driveway
| All times are GMT -4. The time now is 10:39 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
