Water injection control?
Is there a tuning solution out there that'll allow you to control solenoids like water injection or nitrous? I think Unichip will but not sure about any others. What about logging oil pressure?
Thanks! -Mark |
So... If ecutek is a reflash of the stock ecu, how can it operate a solenoid that doesn't exist in a stock ecu? Are there spare inputs & outputs on the stock ecu that you can wire the solenoid/pressure sender to?
My guess would be using the wiring for say, the 2nd O2 sensor or EGR valve and wiring a solenoid to that.
The CPC solenoid output can be re-purposed for use, just like they do for boost control. |
| All times are GMT -4. The time now is 12:00 PM. |
User Alert System provided by
