-   -   Forged Engine & Stage 4 AVO Turbo (https://www.ft86club.com/forums/showthread.php?t=81269)
ChrisD 03-19-2016 11:51 AM
Originally Posted by Tim Radley (Post 2588412)
Any updates?
The oil issue was definitely because of oil being passed back into the inlet manifold through the PCV system instead of getting caught by the catch can. Engine builder quickly spotted and rectified this by changing the way the catch can hoses are set up (free of charge, even though it wasn't him that installed it originally - so thanks for that Ricky!).
Once that was all sorted it went back to Fensport for the final map. They did encounter some fuelling issues at very high RPM but got that sorted in the end and rang me yesterday to say it is all done. Apparently they've got it running 1.2 bar of boost (17 psi) through most of the rev range and said it pulls really well.
Picking it up on Tuesday and will be taking it to a rolling road day that the gt86 FB group has organised on the 27th so will see what power its making exactly. I'll update this thread with impressions of driving it once I get it back
ChrisD 04-01-2016 03:17 PM
http://s10.postimg.org/tfj7mw07t/20160327_174252.jpg
Got it on the dyno last weekend and as you can see peak power at the flywheel was 335 bhp and 275 lbs ft of torque, which is quite a bit less than we were expecting.
Considering someone else with the stage 3 turbo running 0.8 bar of boost got 325 bhp (not sure if that was on a different dyno though) it seems odd that stage 4 turbo running 1.2 bar of boost would only be 10 bhp more. The stage 3 run was on stock compression ratio whereas I'm on 10:1, but surely the extra boost should easily make up for that and then some. Of course this is only peak power, its possible mine is making more power elsewhere in the rev range but I don't have a graph of the stage 3 to compare to.
Fensport suggested that perhaps the tyres were slipping on the dyno as this seems like a very low figure to them for the setup I'm running. We did have issues with the tyres spinning at first but the guys running the dyno strapped the rear subframe down and said they were happy that the tyres weren't spinning after that. Fensport did also say when they mapped it that they could push it and probably get another 20 bhp out of it but that they'd rather keep things safe especially as I'm going to be bouncing it off the limiter at drift days every now and then (thrashed it at a drift event just 2 days ago and it survived).
Regardless of the numbers, I'm happy as it pulls really well now - definitely noticeably faster than it was before with 0.8 bar on the stock engine. Everyone that I took out for a spin at the GT86 dyno day was shocked at how fast it was so I guess that's a good sign lol spins the wheels up easily as well and that's what I wanted.
Next job is getting an extra set of calipers mounted to the rear so we can get the hydraulic handbrake working, and also fitting a 1.5 way LSD. Fun times :)
drewhusaf27 04-01-2016 03:23 PM
That's awesome man! Thanks for the post the suspense was killin me waiting to see how it did. I did also expect it to do better on stage 4 than that though. Let us know what you find out!
spitfire481 04-01-2016 04:17 PM
something doesn't seem right. i made 300whp on regular pump gas with a base avo kit around 11psi. 400whp at 18psi on e85. even with the compression drop, 17psi with the slightly larger avo turbo i feel should make way better than it did. either way, glad you got it all sorted out and running right again. numbers don't really mean a lot anyway, its how it feels :thumbsup:
ChrisD 04-01-2016 08:50 PM
Yeah that's what we were saying, people seem to make this much with way less boost and on the lower stage turbo kits, so it does seem a bit odd. Fensport also said when they mapped it and logged everything they didn't see any kind of drop off in torque towards the top end like there is on the dyno graph.
So I dunno, I could probably get better numbers if I went on a different dyno and put better tyres on and had some more weight over the rear etc etc, but I'm not bothered about dyno numbers enough to do that. It drives great now so its all good
drewhusaf27 04-01-2016 09:21 PM
That's all that matters is the you are happy with how the car drives. Numbers are all that matter to some people.
s2d4 04-01-2016 09:35 PM
US dyno vs the world.
Their dynos read a lot higher
totopo 04-01-2016 09:52 PM
0.8 bar @ 12.5:1
You are running 11.6 PSI of boost at an altitude of 0 feet. Your motor's static compression is 12.5 :1. At this boost level and altitude your effective compression ratio is 22.36 :1.
1.2 bar @ 10:1
You are running 17.4 PSI of boost at an altitude of 0 feet. Your motor's static compression is 10 :1. At this boost level and altitude your effective compression ratio is 21.84 :1.
ChrisD 04-02-2016 09:15 PM
Originally Posted by totopo (Post 2607470)
0.8 bar @ 12.5:1
1.2 bar @ 10:1
If its that simple then wouldn't the car be making less power now than it was before?
Tim Radley 04-04-2016 06:44 AM
That's pretty low power for the spec like you say and that turbo looks nasty and laggy for the power. Power coming in at that rpm on most other 2.0 engines I build are all making 700+bhp
What compression and leakdown figures did you get? Just thinking maybe there is an issue there.
What is your oil consumption like now and is the catch can filling with oil?
Why is the boost so low, surely you could easily run 2 bar now?
Nigelr32 04-04-2016 02:11 PM
Just a thought Chris, You have a Stage 4 now, but not the bigger pipework that the kit comes with? Didn't you also mention Adrian had "tuned" this turbo?
ChrisD 04-09-2016 09:15 AM
nah I got the larger intercooler pipes etc installed at the same time as the stage 4 turbo. Yeah they've tweaked this turbo to give slightly more bhp at the top end. Fensport said in their logs they don't see the air flow or anything dropping off towards the top like the torque does on the dyno so that's another thing that makes them think maybe the wheels were slipping.
ChrisD 04-09-2016 09:22 AM
I don't think this turbo will give anywhere near 2 bar of boost. Fensport said the most they got out of it was about 1.3 when they were using it on their car (race fuel, stock engine internals) and even on the stage 5 that they've just started testing they can only run 1.5 bar so far.
I've not seen dynos from other people using different turbos on a GT86 but I thought it was pretty normal for the power to start kicking in at about 4K RPM on a turbo GT86 (especially now that I'm on 10:1 CR pistons).
Like I said before, they did say they could push it further but I'd asked them to keep it as safe and reliable as possible because its going to be sitting bouncing off the limiter on drift days quite a lot.
Lets face it whatever the dyno results were, someone would be on here saying they could have tuned it better etc etc. I do think the dyno results are a bit misleading and that the tyres might have been slipping, but I don't care about dyno figures enough to go prove that just to satisfy people on a forum. At the end of the day I wanted it to be faster but still reliable, and that's what I've got. So I'm happy :)
Nigelr32 04-10-2016 06:48 AM
Good on ya mate!! Enjoy!!
