Ran Sacramento raceway yesterday. First run hit traction control and cut power to the wheels, hitting a 14.5. Then I ran a 14.158 with with traction off and sport mode, this is with a let off before the end (14.2 dial in). This is with the kraftwerks c30 Carb tune.
I think it could easily run a high 13 with the right conditions, but we didn’t get a second chance to practice before we dialed in a time. So I didn’t know what it would put down without traction control. My friends are doing test n tunes next month and it should be in the 13s then. Mods: Kraftwerks c30 CARB tune Perrin 2.5 catback Gram light 57dr 17x9 Almost used up hankook v12 https://scontent-sjc3-1.xx.fbcdn.net...bc&oe=5B4B0FB6 https://scontent-sjc3-1.xx.fbcdn.net...9b&oe=5B31E880 |
What is considered a good 60' time? I don't expect good times with stock struts and Eibach lowering springs. I also didn't wanna launch hard and break something. |
Knocking half a second off the launch would equate to much more than that by the end of the quarter. |
Took mine to the strip for the second time, and ran the best I've ever done! :D
Mods: - Skunk2 Powerbox CAI - Grams 72mm Throttle Body - Delicious Tuning Flex Fuel Kit - ACE Type-A 350 Header + OP - CSG Touring 86 Catback - Stock wheels and tires! :D https://i.imgur.com/S7953io.jpg |
1/4mi 14.267secs @ 96.570MPH 1/8mi 9.211 @ 77.980MPH 60ft 2.223secs That was on Bridgestone RE730s back in 2004. Mostly stock car. Type-R A-pipe to tip. Type-R pistons. Koni Yellows with Ground Control coilovers with ERS 500lbs/in F, 500lbs/in R. Type-R rear ARB. Lightened OEM flywheel down to 13lbs. HomeDepot special dryer hose into the wheel well CIA. I loved pissing guys off at the track with that car. Hahaha Long story short, seems like your car would be faster than this with those mods. |
2.191 60' 6.149 330' 9.395 @ 76.81 1/8 12.169 1000' 14.521 @ 94.8 1/4 at a DA of 1260ft. spare/jack/baby seat still in the car and all tires at normal pressure. |
Not sure exactly. It was in the winter if I recall and it was in Gainesville, FL so basically at sea level. I did this run with all the mats removed, spare tire jack and rear seat back. The GSR was a 5 speed and didn’t have super short gears. 3rd ran out around 93mph and once you shifted to 4th it didn’t pull that fast so the trap isn’t all that high. I coordinated with a friend of mine and plan to go to the strip on April 21st with my FRS for the first time. It will be interesting to get a base run out of it. |
oops, quoted the wrong post, I meant to ask funnygopher what his DA was
its interesting to compare our runs after DA correcting them. I did some calculations. DA corrected you ran a 14.273@99.538 compared to my 14.327 @ 96.194 ...that Ace header makes some impressive top end power. I might have had you at 1/8th mile, then you pull away to win by .054 and about half a car (7' 7") but 3 mph faster means youll keep on pulling. |
| All times are GMT -4. The time now is 07:09 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
