-   -   Did anybody experience any issues with their oem motor mounts? (https://www.ft86club.com/forums/showthread.php?t=74613)
Astroboy 09-21-2014 11:19 PM
Did anybody else experienced any shaking or rubbing after going FI caused by oem motor mounts?
My OEM motor motor mounts started shaking roughly around 224whp with my avo stage 1 kit. It usually happened after warmed up and driven for 15-20 minutes, Which I thought was kind of strange. It would even shake at a complete stop when warmed up and driven for 15-30..
I even posted a previous thread on wondering what was causing this...
A couple days later, I took it to a shop that works specifically on subies and was thrilled when the owner of the shop told me that it was only a little bit rubbing caused by poor motor mounts. Anyhow, I had Perrin engine mounts installed and all good ever since...
Anyhow, any body else experience violent shakes with their oem mounts?
cdrazic93 09-21-2014 11:40 PM
Shaking? No but @Sportsguy83 had his melt.
Astroboy 09-21-2014 11:54 PM
Cool, thanks for the info!
I searched it up in his forum.. I'm glad he's doing well with his car.
Sportsguy83 09-22-2014 12:22 AM
That's how gossip starts :D It was another forum member that melted not mine :w00t:
Mine are doing good. Never melted.
Also anytime you change to a stiffer mount, NVH is increased.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Astroboy 09-22-2014 12:44 AM
Oh... Lol sorry
Which member had their motor mounts melted if you don't mind me asking?
Sportsguy83 09-22-2014 12:48 AM
Originally Posted by Astroboy (Post 1955905)
Oh... Lol sorry
Tg_1981 it's on the review section of the forum.
midnight23 09-22-2014 04:51 AM
no shaking here yet.
cdrazic93 09-22-2014 01:15 PM
Whoops lol my bad.
Sportsguy83 09-22-2014 01:16 PM
Originally Posted by cdrazic93 (Post 1956437)
Whoops lol my bad.
All good :bellyroll:
Astroboy 09-22-2014 02:28 PM
Are you running the base map?
Astroboy 09-22-2014 02:33 PM
I just finished reading your experience about your avo e tunes from JV..damn I'm glad I finally got mine dyno tuned! Now that I recall, I do remember my engine sounding harsh after averagely driving (a little bit of hard driving,but mostly cruising) every time I got home... I don't hear it anymore after my custom dyno ecutek tune... What was your afr at wide open throttle using both JV's tune and Toni's tune?
Scary shit
Sportsguy83 09-22-2014 03:22 PM
Scary shit
With JV it was running pretty rich.
With Toni it was somewhere close to high 11s and 12s but the issue with that tune was a bunch of different stuff like holding closed loop too long and as a result seeing 16 psi with 14.7 afr, idle dips including stalling, cranking injection all wrong, misfire because too rich E85 (dipping into 9s on tip in)....
Astroboy 09-22-2014 04:25 PM
Interesting,... I read somewhere that the flash tunes by JV were known for running to rich... my current car's afr is usually set in the high 11's-12's as well... I'm currently making 254whp/200lbs with my custom dyno tune using the ecutek whereas with the base tune, I was making 224whp/174lbs With an 2.5 HB exhaust and k&N filter.
With the base tunes I was also getting cel codes like p0171, p117b, and p1170 a day after the install. I then realized I had an exhaust leak right out of the manifold gasket! Anyhow, I replaced the previous gaskets with some sti gaskets purchased at o'reilly's, then I cleared the codes, and it ran strong for 2k miles with no cels. Later started hearing a harsh knock sort of sound coming from the engine. A couple 100 miles later my car was shaking violently! I resolved the issue by switching to perrin motor mounts, I also noticed I had some hidden cel codes that were p0102 and p0113. No cel light popped up for the codes. I finally decided to get the custom tune and was actually thrilled when the tuner told me I had a healthy motor and he managed to get rid of the codes.
Would you like yo hear about my experience with my fa20club.com flash tune with their intake system? :D
Sportsguy83 09-22-2014 04:32 PM
Post it in one of the many vendor review threads there is active about them :thumbup:
