-   -   3rd Brake Light *Low Profile Carbon Fiber (OMG CARBON) (GB OVER- see link) (https://www.ft86club.com/forums/showthread.php?t=74299)
37 09-18-2014 02:32 PM
Originally Posted by wheelhaus (Post 1949077)
PLEASE NOTE: The gray tape is temporary. I'm working with our 3M rep to test out some black tapes that are also UV resistant. I want this shroud to be hardly visible at all.
3M 4947F should fit the bill. It's black, UV-resistant, and 49 mils (1.1mm) to dampen both vibration and be thick enough to wedge something between the glass and carbon housing in the event it needs to be removed. It's designed specifically for adhering items to glass and resists both paint and plasticizer. Carbon fiber and fiberglass resin—especially when molded smooth—has enough surface energy that adhesion and any possible off-gassing should be a non-issue.
wheelhaus 09-18-2014 03:01 PM
Originally Posted by Rosticles (Post 1951730)
I definitely want one of these, preferably in a less expensive fiberglass. I think it would also be nice to make a matching triangular piece to cover the wound left on the back dash after removing the factory light. I was going to make one myself from plastic, but I think it would be smart to pair these items for sale.
I am already planning on including three felt patches, the edges can be seen from the rearview, but even on untinted glass they're nearly invisible. I'll look into making a cover of sorts to see how best to handle it. I want to avoid any hard surfaces near the glass though, rattles be the devil, ya see...
Originally Posted by DarkestBuddha (Post 1951803)
can you make it so it has an extension that does into the headliner and bolts into the middle push cap and so it keeps pressure against the back window
so we dont have to use double sided tape on tint.
also how bright is that light under direct sunlight
I was thinking about this, but I had a HELL of a time trying to get that center button off, I just gave up. And I was using interior panel tools etc. I do have the ability to bend and even bond an aluminum foot as you suggest, but it's not going to happen with the first design. It's on the radar though and I'll keep you guys posted.
The light is really bright, enough to bloom on a camera. It very very close to the same color and intensity as the OEM tail lights. I'll take a photo if you'd like.
Originally Posted by 37 (Post 1951934)
3M 4947F should fit the bill. It's black, UV-resistant, and 49 mils (1.1mm) thick to dampen both vibration and be thick enough to wedge something between the glass and carbon housing in the event it needs to be removed. It's designed specifically for adhering items to glass and resists both paint and plasticizer. Carbon fiber and fiberglass resin—especially when molded smooth—has enough surface energy that adhesion and any possible off-gassing should be a non-issue.
4929, 4949, and 5952 are all considerations in the line of ~45 mil black VHB tapes. Do you think 1/4" would be sufficient or should I stick with 1/2"? 1/4 would be easier to remove if necessary.
37 09-18-2014 05:33 PM
4929 / 4949 / 5952 are all for bonding metal and plastic. 4947F is specifically for bonding various substrates to glass. While all of these should work, my money is on 4947F above all else. I have experience with that exact tape.
1/4" wide is more than enough. Overall weight is likely under a pound and most VHB has pull strengths in the 30+ PSI range. Even a 1/4" strip should take 10 PSI or more just to pull off. I'd rather fight 1/4" worth of VHB than 1/2".
Keep in mind this could get dust, bugs, haze, or other unknown variables behind the glass and require periodic cleaning. I could almost see a version with a long tail that tucks into the headliner and puts enough pressure on the housing against the glass to stay in place with only a felt lining. Cleaning would be vastly easier. It could even bolt to the antenna area. Just a thought.
DarkestBuddha 09-18-2014 05:42 PM
okay cool.
i actually did this too but i added the aluminum foot and the headliner button goes through a hole in the aluminum to keep it stable and up there without the need for 3mtape. however due to the aluminum, the part that was supposed to be flush to the headliner is slightly lower then it now.
Also what light are you using, can i get a link.
my light is near invisible in direct sunlight through my tint.
at night it is very bright tho.
wheelhaus 09-18-2014 06:07 PM
Originally Posted by DarkestBuddha (Post 1952269)
okay cool.
I am using the same light from the first thread I referenced, seen here. It is this light from www.superbrightleds.com
GremlinGSP 09-18-2014 06:14 PM
interested.
wheelhaus 09-18-2014 06:24 PM
Ah perfect, that's exactly what I need. Unfortunately they don't make 4947F in 1/4 wide rolls. My supervisor was under the impression some vendors can cut custom widths... I'll make some calls and see if that's possible.
I'll work on a way to mount it with a bracket, seems people definitely want that option, but its going to be more expensive. Using tape is the quickest, cheapest way to mount a razor thin light like this. I guess it is possible for debris/etc to enter the housing, but with felt covering the areas where tape isn't (moreso than seen in my photo), accumulation should be minimal if any. Nearly every headliner I've pulled from several different cars revealed a pretty clean area behind it.
To boot, the top edge of the carbon flange actually butts against a piece of foam or something bonded to the roof structure/skin, so in combination with the felt it sort of acts as a poor-mans labrynth seal.
37 09-18-2014 07:22 PM
Depending on the volume you produce, fabricating a cutting jig for the tape wouldn't be difficult. It's added time and time is money. If you only crank out 20 units then a custom tape order probably wouldn't pan out. You'd have to do the math on length versus cost. Each housing is ~2' worth of tape. One roll of tape would last a while.
Tape is indeed the quickest and easiest. If the housing is sealed well enough to keep out dust/bugs/haze then I'm all for it. My BRZ windows seem to get hazy quite quickly despite not smoking and the car being over a year old. The plasticizer used in the interior panels must still be off-gassing.
protpibe 09-18-2014 07:51 PM
Nice!
I'm absolutely 100% in if you start producing these.
cdrazic93 09-18-2014 11:04 PM
mm. Me likey. Me dont likey the carbon fiber because $$$. If it was FRP or fiberglass thatd be a different story
..maybe more affordable then.
thatfilipinoguy 09-19-2014 07:33 PM
in for GB.
Tjbugs1 09-20-2014 03:49 AM
Just posting so I can follow about a GB.
White64Goat 09-20-2014 02:34 PM
I'll throw this question out there as no one has asked so far. Does the housing cover over any of the wire grids for the rear window de-fogger? Asking because if the LED should fail, an easy removal without damage to wire grids would be necessary.
If the housing doesn't contact any of the grids, would black RTV silicone sealer be an option?
GTSRolla34 09-20-2014 03:37 PM
I'm interested in a group buy. I'll keep an eye on the thread.
