Real-time Oil temperature Analysis - Pre/Post Coolant Loop Oil Cooler Install
It's a bitch to just run the hoses for me since I have a Kraftwerks supercharger in the way. Also the oil gasket on the OEM cooler seemed to have expanded and now does not want to get seated without popping off. I'm trying to use 1/2" and 3/8" hoses but what you just said has me concerned about the hoses being too big for the throttle body ports. Starting to wonder if this is all worth the ~4 def F cooler oil temps.
I think 3/8" is fine for the throttle body fitting. Loose is probably not 100% accurate.
It went on to the TB without any issues compared to the oil cooler, so it just felt really easy. If you make sure the hose clamps are tight you should be fine. I just got back from my first drive in the car, nothing fancy/fast. No leaks, and oil temps were within 4C of the coolant. |
@Kostamojen my bad 10-20 instead of ~5. It has just been frustrating getting the hoses to connect and fit. I know someone else got this to work with the KW kit but I'm not sure it's worth it for me. Seems like the greatest benefit for me is to extend the oil filter up higher so it'd be easier to change in the future (I may just forgo connecting the lines ).
Hi guys,
I have done the Forester XT Oil cooler route (done from the coolant line not through the throttle body) and had decent results. Perhaps the other change could be a lower temperature thermostat to increase the temperature differential between the coolant and the oil in the heat exchanger. It is a shame that the thermostat is not in a really nice to change spot like the oil filter is so you could change the thermostat easily without draining the coolant if you were intending to drive the car hard. Not sure what the impact would be for daily driving with that type of thermostat but it might be worth 5 deg. Celsius. |
Even running coolant from the OEM lines instead of the throttle body still sees coolant to oil temp differential increase after 15 mins or so of hard driving differential about 45F degrees so another 9F/5C degrees wont gain you much more heat transfer possibly 10-15% maybe. But every bit helps and its a relatively cheap and easy mod. If your going to do sustained long track runs it probably worth the expense of an air/oil radiator type oil cooler. I did see someone with a double stacked sandwich plate running both types together. They must have made a custom centre mount to hold both plates maybe. |
I have a similar setup on my 2zz GE- they came standard with these, and after about 5 super hot laps on Kyalami in sunny south africa-- track temperature 50 deg + Celcius and ambient temperature 30 deg Celcius, the oil temp starts to creep up to around 115 deg Celcius, So it works to an extent, but has it limits, on a dedicated track car it will not be sufficient.
First of all, that quote is relevant to all threads no matter what. Second, getting my words out is more important than giving me credit. Third, methinks it was an ad bot of some kind, but an ad bot with good taste. :party0030:
| All times are GMT -4. The time now is 07:43 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
