| civicdrivr |
05-23-2015 04:05 PM |
Originally Posted by Captain Snooze
(Post 2259710)
Stupid question time. Ready?
Not knowing anything about American V8s and doing a quick Google what is it about the LS1 that makes it so appealing over the myriad of other U.S. V8s available?
Am I correct in saying that an LS6 is externally the same as an LS1?
Yes, the LS-whatever are externally the same size, save intake manifold differences and accessories. The only engine that isn't the same is the LS4, which is a FWD config that was used in the later model Impala SS'.
The LS6 is from the C5 'Vette Z06. You can run it but LS1s are more popular. Both are 5.7l, but the difference is in the heads and I believe the pistons (I may be wrong on this though). Both are aluminum blocks.
The truck engines, which are a dime a dozen, are typically iron blocks, but there are a few that are aluminum. I'm targeting the L33, which is an aluminum block 5.3l and utilizes similar heads as the LS6. A port job and a nice street cam should net 390ish whp and be nearly bulletproof at that. At current rates, I expect that build to run about $1900 max.
Unfortunately, prices for the aluminum engines are on the rise thanks to the drift tax, but they're still cheap compared to other engines.
Sent from my XT1095
