If he has an OFT and an Auto he should be ok. I would say he has triggered the U0155/U0073 can buss comms codes or an auto trans code after flash or by plugging/removing OFT while car is running He should just be able to use oft to clear codes and be good. |
Cruise control doesn't work with cel btw.
as ive stated, i have an auto [and its also in my sig]... i guess i did not flash a wrong map, but what now?
i got a cel that i cannot read/clear with my oft and my cruise control light stays on orange... |
yes, cruise control gets disabled with the cel
afaik, the flash went fine... i followed the guide video and did everything correctly.
i have reuploaded the B01D map via oft manager thru my pc and i plan to reflash to see if that helps. |
Help!
http://www.datazap.me/u/scionfrsfan/...6?log=0&data=1 Can someone please check this out. Recently my check engine light came on, code P0456 (Evaporative Emissions System) The car seems to runs fine. I do notice on start ups the rpm rises then drops right away, then starts to idle steady. My car is STOCK. I am running stage 2 EL E85 V2.06. Weather is starting to get a little bit colder, not sure if that has anything to do with it. Is E85 causing the problem? I'm not exactly sure what to look for, can someone check my data to make sure engine is okay! I checked gas gap (silly stuff), so far light has come on 3 times. Once a few weeks ago, the last two within a week. Thank you :)! |
try removing battery cable for a minute, should reset al control units in car. |
*everything is figured out*
i updated the oft via the manager software on the pc and reflashed the map. thanks guys for all the help ! |
cel is gone for good and the cc works perfectly fine... im not sure what that orange light was all about...
I have a serious problem. I flashed (a minor update), and when it says key on and confirm. I can't turn the car on at all now, so I can't flash anything.
Shiv@Openflash help :( I've attached the file I flashed. |
| All times are GMT -4. The time now is 09:13 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
