anyone else get a really loud backfire if you rev out 1st and then push in the clutch to put it into 2nd? I get this all the time since putting the 2.0 maps on.
are you running catless? i get the same but im also running catless headers and front pipe. its nothing to worry about. its a little back fire from running with no cats. also @steve99 thanks for pointing out the maf scaling. car runs a lot better now and the a/f is pretty much dead on and where it needs to be. thanks again |
I run 2.0 OTS and a catless UEL with no backfiring at all.
Sent from my SM-N900T using Tapatalk |
required if you change position of maf sensor, diameter of tube maf sits in or something that altrs flow around maf sensor |
haha you beat me to it |
Thanks everyone! You guys are great!
Would it be benificial? Probably yes. |
double post
heres a little cruising log i did. to me it looks good. only thing i see is around 2800-2900 rpms i will run a tad rich under light throttle and load. what do you think?
http://www.datazap.me/u/lucid215/cru...log=0&data=1-7 |
| All times are GMT -4. The time now is 09:13 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
