-   Software Tuning (https://www.ft86club.com/forums/forumdisplay.php?f=88)
-   -   OpenFlash Tablet: OTS v2.0 Beta (132 new maps, 12 new XMLs) Available for Download (https://www.ft86club.com/forums/showthread.php?t=70796)
Apoc 07-27-2014 11:56 PM
@shiv I started getting P0170 CELs when idling today so I flashed back to stock. My exhaust has been backfiring and has been louder the last couple days so I checked my gaskets and made sure my OFH was wasn't leaky. I had to replace the gasket at the OP/FP. Now this P0170 code leads me to suspect that I have a bad MAF sensor and my fuel trims are getting messed up.:(
steve99 07-28-2014 12:42 AM
stock intake ?
check for vacuum leaks especially gasket at maf sensor and clamp at throttlebody and vacuum hoses on intake manifold sound tube ect
if oiled filter chech and clean maf sensor
Apoc 07-28-2014 01:40 AM
Originally Posted by steve99 (Post 1868738)
stock intake ?
I have a TRD intake and did take the MAF sensor out and gave it a good shot with connector cleaner. I will check clamps and hoses tomorrow. I was going to take in to the dealership but now I think I will avoid the frustration and expense and fix it myself.
Brinks 07-28-2014 02:14 AM
Just got my OFT, trying to upload the new beta map. Not sure what map I'm supposed to use
700C, 900C, A00C, A01C, B00C, B01C, 700D, 900D, A00D, A01D, B00D and B01D
What's the difference between these files?
somejace 07-28-2014 02:24 AM
Well I went through this entire thread and didn't find a answer
What's the difference from the older version and this 'new' beta one.
I'm using e85 EL currently with zero issues.
Is it a difference that I should really make the upgrade or just continue what I'm using now. Thanks.
Brinks 07-28-2014 02:31 AM
If you download the new beta the changes are noted in a read me file.
YMAA 07-28-2014 03:09 AM
You need to hook the tablet up to your car and read the stock ROM to know what version you have before you know which version to upload to the tablet. Have you done that yet?
Brinks 07-28-2014 03:20 AM
Thanks. My car is on jacks right now for multiple reasons, I was just messing around with the OFM trying to preload the files. I'll hook it up tomorrow. I'm still curious why their are so many different version for the same software. I know it changes for 6mt-Auto but does it change for all the different trim levels depending on what type of electronics are available?
phrosty 07-28-2014 03:42 AM
Just version numbers, not trim related. Like any software, the ECU code gets updates occasionally. The first run of cars got 700, and the latest run come with B01.
wparsons 07-28-2014 08:50 AM
Originally Posted by xxBrun0xx (Post 1868618)
Does the 93 stage 1 change anything other than another HP/tq curves? Eg idle speed, Rev limit, pedal position map, etc? Just curious if some of the changes people are noticing are plecebo?
If you want to see, just open up both ROMS in the RomRaider software and view the differences.
It's hard to give a placebo based on idle speed, pedal mapping, etc during WOT pulls.
I haven't checked, but I would suspect the 93 octane tunes have similar differences in mapping as the e85 tunes, just not as drastic. More spark advance to go with the increased detonation resistance.
355rockit 07-28-2014 12:26 PM
Will using the Sport button mess up the ECU re-learning after flashing the ROM? I was uncertain as to the affects of using the Sport button after the OTS tune is flashed. I was under the impression that the Sport button initiates some sort of throttle remapping.
Tt3Sheppard 07-28-2014 12:30 PM
Curious to see the difference between the 91 1.59 Stg 1 tune and this updated 93 tune. I've been running 93 octane since original flash. Will be trying this later today!
wparsons 07-28-2014 02:30 PM
The sport button doesn't change mapping on the stock tune (or any OTS tunes).
Readytoxplod 07-28-2014 05:28 PM
downloaded 93oct A00c from beta 2.01, and launch control is active, how to I activate flat-foot shift? I tried it (shifting while on the accelerator without lifting fore shift) and it just revved to the limiter. How do I activate it?
