Thread should say I installed something wrong and blew my motor...
The fuel cut on these cars is overly aggressive. When the car over shoots boost, which creates a high cylinder pressure in it's own then suddenly CUTS FUEL to "save" the motor the cylinder pressure spikes even higher. It's basically one big detonation. So while it can save you sometimes, on higher boost applications with the shitty cast piston and crappy little rods it can also hinder as well. This is even the case with the extra custom maps I setup to soften the FUEL CUT.. @nelsmar you care to comment on the aggressive overboost? I know we had a conversation about it. You know what would have saved this motor ultimately? Following the instructions that came with the waste-gate and using loctite on the fittings. This way no one would be pointing fingers and Kai would have a running car still. Like I told Kai elsewhere if this was a shop error, I would be the first one who makes sure the shop pays for the mistake. Unfortunately Kai was the installer. This won't be the first or last time someone does this, hopefully a few people see it and learn from it though. A little off topic but.... You guys and your tuner/tuning witch hunts make me laugh. A wheel could fall off someone's car and there will always be one guy asking who tuned it and claiming maybe it's the tuners fault. For the amount of people who think they know every thing on these boards, I see a lot of guys that don't seem to realize that your double and tripling the stock Hp on these cars. Shit will break, it will cost you money. |
Everyone wanted to swap to a SR in a S13/14, and make "easy" boost. The part about it being "easy" is that the manufacturer (Nissan) already did the bulk of R&D on the engine, so there's a better starting point. Those wanting to boost their stock KA24 engines could achieve factory-like levels of reliability, but that involved proper tuning (and proper install of parts). This got expensive real quick... The chips fall the same way... install needs to be correct, tuning needs to be correct. Just because you buy a factory turbocharged car doesn't mean you will end up better, it just means a larger company has done the R&D and backs it up with a warranty because of the more extensive testing. -alex |
so my motor blew up on dyno today jdl kit gtx3071
Missed some stuff
I'm not taking sides here as i know more than anyone motors let go perhaps a lot more often than what people see or read online...It's part of the game and anyone wanting to play should be prepared.
I've personally lost a motor before due to a melted wastegate line, it was 100% my fault and a last minute hack job to get on the dyno at 2am to make an event while waiting on AN lines to show up the next day. However i've never seen these fittings or plugs back out or completely fall out. I've also never used locktight nor seen anything in Tial's instructions (I just opened a few MVS and MVR gates here at the shop to check) to do so on anything other than the water fittings, which makes sense for water based on the thread used. I've usually found because of the difference in materials in the gate vs. the fitting the fittings are usually tighter and harder to get out over time due to expansion/heat cycles, etc. |
1. The car had over-boost protection for starters. 2. LOL at I "now know to watch for over-boost situations"?.. Who are you and what have you accomplished again? I like to think my 14yrs of tuning knowledge might qualify me as experienced... If it has boost, it has overboost safeties. I don't think I would be trusted to tune 15-1600whp boosted street cars for big name shops or 7-8 second 4-6cyls, even your 500+whp FAs like @Hawaiian and a few others if I didn't know that boost limiters need to be in place... but thank you for your opinion on what I know or dont know.. 3. Your "FACT" Do you know how cylinder pressure works? I love your "facts" of fuel cut and I loved JamesMs post about "theories".. Goes to show how much actual experience some of the tuning "gurus" around here actually have. I don't need to sit here and give you all knowing gurus a lesson in how cylinder pressure works. Fuel cut causes an abrupt SPIKE IN CYLINDER PRESSURE, on a motor that is already making high cylinder pressures from its high compression and now forced induction. Do some research, or maybe if you do have any actually knowledge look at progressive fail safes for boost, rpm.. or full engine stall fail safes for stuff like fuel pressure drops and oil pressure in some of the standalone ecus. Fuel cut works relatively well on cars that are not running excessive cylinder pressures from high compression to start with. With that said EVEN STOCK STI/WRXS will crack ring lands from spikes in cylinder pressure like detonation from the lean condition at PeakTQ in the stock tune, hitting the rev limiter hard on the old cars ( they now use a progressive closing of the throttle in the mapping to avoid this) or from hitting the boost limiter when they boost creep. Shitty cast parts don't like spikes in cylinder pressure. On a side note, I didn't know they banned JamesM.. I was looking forward to the arguments and I was sad to see his comments gone. Jr |
Guys like you take the internet way to serious. You should start some sort of forums rights support group. This way you guys can talk about how bad the forum is because they dont like your OPINIONS.. or as you call them "facts" |
There's a reason why @jamesm has separated himself as the clear cut best tuner for this platform. The results speak for themselves.
| All times are GMT -4. The time now is 03:40 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
