-   -   Nameless Performance BRZ Axleback Exhaust (https://www.ft86club.com/forums/showthread.php?t=7038)
dabocx 10-31-2012 09:31 PM
Sounds even better with a tune (though it is a decent amount louder at some parts)
I just need the header and intake!
jimbobrand 10-31-2012 11:16 PM
Originally Posted by QFry (Post 531532)
get underneath your car and figure out which hangers arent hanging straight...and then get a pipe and gently bend the hangers on the exhaust and re hang again. Im willing to bet if you move the two passenger side hangers towards the rear of the car 1/2" it should even the problem out.
I tried that while installing the exhaust. No matter how you position the exhaust on the hangers it will still kick out the passenger side about an inch when you bolt it in place. Hangers aren't the issue, its the angle of the flanges.
OrbitalEllipses 10-31-2012 11:20 PM
Originally Posted by jimbobrand (Post 531721)
I tried that while installing the exhaust. No matter how straight you get the exhaust on the hangers it will still kick out the passenger side about an inch when you bolt it in place.
Stock rubber hangers or polyurethane hangers?
QFry 10-31-2012 11:22 PM
how much play do you have in the mid pipe? mine moves a decent amount and allows for adjustment...if yours does not move try loosening the mount for it then adjusting the axle back and tighten the midpipe once it is set...
jimbobrand 10-31-2012 11:32 PM
Stock rubber.
My mid pipe had almost no play when I installed the axelback. I might try that when I have the time and place to do it.
sierra 10-31-2012 11:37 PM
I can understand why you can't get it into alignment with the hangers.
It's a rigid structure that's misaligned just as you say. You might align the tips to left or right with the hangers but you certainly wont align them front to rear because you need to bend the axle back to do it.
QFry 10-31-2012 11:44 PM
please explain...the four hangers can only pivot front to back like a swing (bad design imo) and you can physically slide the bushings from side to side but that doesnt change the fact that the bushings themselves rotate front to back.
sierra 11-01-2012 07:58 AM
You have a pipe that's fixed at the front and rigid in structure, hanging by 4 rubber loops at the rear. Any movement can only be from side to side at the rear since you cannot compress the pipes but may move them slightly to each side.
A flexible fitting at the rear of the centre pipe would allow the axle back to rotate about that point and then you could tuck the offending right hand tip back by bending the hangers a bit.
phm14 11-02-2012 10:04 AM
I considered "adjusting" the hangers, briefly, before realizing that there is no possible way that will solve the problem. The problem is @ the flange attachment angle, and that is what must be corrected.
Sportsguy83 11-02-2012 10:06 AM
They suggested two solutions (posted earlier in this thread by someone who spoke to the on the phone) and if that didn't solve the issue, to call them up. You can try that.
Tomzilla 11-02-2012 10:56 AM
Just got my blacked out offset exhaust. Question- We use the stock seal between the axleback and midpipe, yes? Just making sure I wasn't missing one in my package.
QFry 11-02-2012 11:00 AM
Yes, you use the stock gaskets...
Tomzilla 11-02-2012 11:12 AM
Thanks, brotato chip.
Sounds nice. I'll take a picture for those who would like to know what the black out looks like.
Tomzilla 11-17-2012 09:26 PM
http://img560.imageshack.us/img560/2014/dsc0712ofx.jpg
Blacked out.
