I'm making 270 on 91 with the greddy kit, if you plan on doing e85 you'll be at 300 no problem. Definitely fun on the streets with the quick spool.
I find most of what he has to say yo be shady anyway, so I was OK with the decision. |
Your power will be limited by the fuel you run. 91 max is roughly 300 with a really good tune. 91 with meth injection maybe 350.
Higher numbers can be had if you run E85 if that's available to you. Even at these numbers you'll need a clutch, catch can, radiator and fans if you track or drive hard. Reliable higher numbers and you're in short block territory. I love my GTX2867r Full Blown premium kit with meth on 91. FB is a great company to deal with as well. Their customer service is great and I'd buy from them again. |
Yes Crawford's is making that power on his built engine of which he blew up several. He never addressed any cooling issues other than the $700 being heat shield. The powerband of that kit is awful too, it peaks at like 4500rpm then falls off a cliff. Yeah it will make a daily driver feel fast but if u try to race with the gearing we have you'll have to short shift the crap out of it lol
Aside from the other great kits mentioned here you also can take a look at ptuning's quality turbokit.
ive been doing my research too as im in pretty much the same boat, and PTuning's kit stands out to me because they are making around 290whp on 6.5psi of boost. I haven't seen other kits that can achieve that power within the low amount of boost.
or 3psi on a 88mm turbonetics
Octane makes a huge difference for this motor. For example my ptuning kit maxes out at 280 whp on CA91 octane and needs 8-9 psi to do it. On 93 it would probably be more in line with ptuning's results. |
| All times are GMT -4. The time now is 10:48 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
