-   -   4th brake light? (https://www.ft86club.com/forums/showthread.php?t=68347)
mervingee 06-18-2014 11:11 PM
4th brake light?
So earlier today I saw an frs with the brake light flashing at the bottom where the reverse lights are. I was wondering how can I do that?
Husker BRZ 06-19-2014 12:23 AM
This gives you the option to pick what functionality you want out of it.
http://www.ft86club.com/forums/showt...th+brake+light
Wizardhat 06-19-2014 12:46 AM
I have that set up
I got the Valenti back up/fog light/4th stop light. Looks wicked when backing back and a great upgrade with the lights on. Stop light is the foglight blinking instead of being on continuously. Only works when headlights are on out of the box. One can customized some features if they know what they are doing. No problems with it like with the Valenti taillights turn signal failure. Recommended from my experience. Install tip: undo the bottom clips securing the lower bumper and pull it down a bit so you have the space to install it easily. The muffler makes it a pain if you dont.
IgnitionGundam 06-19-2014 01:38 AM
WIZARD HAT? Don't forget to put on your robe too. :lol:
Wizardhat 06-19-2014 10:45 PM
No it is not Wizard Hat. That is two words. It is Wizardhat, one word, as in Wizardhat Studios which is how I am known as a fine artist.
boredom.is.me 06-19-2014 11:23 PM
I wouldn't bother with any of the "kits". You can do it yourself with equally good (better than some) for about $40.
Here is my parts list.
18 SMD Dual Intensity
7443 Socket
Any 3 conductor wire will be fine. I used less than 5ft of RGB wire, and just peeled the blue away.
IgnitionGundam 06-20-2014 02:32 AM
I thought you were referring to this old chat!! It's a classic btw.
http://www.albinoblacksheep.com/text/bloodninja
Wizardhat 07-01-2014 04:11 AM
:) I knew you were. :w00t:
ericmpena 07-01-2014 04:22 AM
http://www.ft86club.com/forums/showthread.php?t=24188
Kit 3 is the one with the flashing 4th brake light.
http://s1099.photobucket.com/user/Ja..._2056.mp4.html
boredom.is.me 07-01-2014 06:53 AM
The flashing comes from a simple $10 module that you can get from many different places. Don't over pay for simple stuff.
mackdaddytran 07-01-2014 12:17 PM
7443 Socket
Any DIY tutorial for an electrical noob?
rocklin662 07-01-2014 08:55 PM
This? http://www.ft86club.com/forums/showthread.php?t=10816
Sportsguy83 06-11-2015 10:59 AM
Where can I get the flashing module?
Thanks!
Gunman 06-11-2015 11:53 AM
I used a turn signal flasher :)
