-   -   Anybody running Exedy stage 2 clutch? (https://www.ft86club.com/forums/showthread.php?t=64173)
Astroboy 01-06-2016 05:31 PM
Originally Posted by Kiske (Post 2500056)
nope that is grinding, lw flywheel chatter mostly sounds like something lightly rattling.
What could cause it to grind? I did everything correctly and torqued everything up to spec..... I'm mad.
Sent from my LG-D850 using Tapatalk
Kiske 01-06-2016 09:12 PM
Dry pilot bearing, inproper install, glazing, tob incorrect install, bent fork, insufficient pressure plate.
When it is grinding can you feel it though the clutch pedal?
When dose it happen? Coasting? Accel, Decel? Idle
Astroboy 01-06-2016 09:49 PM
Only when I decelerate in gear. Don't hear it during idle. Don't hear anything during idle. Hear it when accelerating in fourth on low rpms tho. I don't feel the grinding.
weederr33 01-08-2016 12:55 AM
Have you had a chance to see if it was grinding?
Astroboy 01-08-2016 02:17 AM
Suppose to meet up with someone who is more informed on these clutch tomorrow. Hopefully it's nothing major. I can take out the transmission again, I just don't want to go through the hassle again
Astroboy 01-10-2016 12:20 AM
A good source told me it was the springs on the clutch disc Because the noise stops when I pop it in neutral, or press on the clutch pedal
weederr33 01-10-2016 03:08 AM
So do you need to replace the clutch or just grease them up? And at least it's not grinding or out of wack.
Astroboy 01-10-2016 12:01 PM
I was told that exedy clutch disks were notorious for this. He told me that if I were to remove the trans again to see what was up with the noise, all I would have to do is shake those springs to confirm that it is the springs.
weederr33 01-10-2016 12:03 PM
Hopefully it will be an easy fix
Astroboy 01-10-2016 12:07 PM
It's normal. The only way to fix it is to get a better clutch kit. Oh well
weederr33 01-10-2016 08:38 PM
Well shit... :thumbdown:
Pneub 07-18-2016 01:42 PM
I just had this clutch fail on me after 30k miles. This is after my ACT clutch failed almost immediately. Not sure what the issue is with this car.
Edit: I had the Exedy stage 1 fail one me
weederr33 07-19-2016 10:41 PM
I thought you had the stage 1 fail on you?
Pneub 07-19-2016 11:47 PM
My bad. I meant to include that part. Corrected: Stage 1 failed on me after 30k
