rear diff riser, welder needed
So I'm planning on purchasing the rear diff risers from PSM, as well as the sub frame risers as well.
Only issue is that one of the parts need to be welded in. what shop do you recommend for a job like this or can any welders do this with the correct instructions? Ive found out that just changing out the rear axles is not good enough to drive this car hard when lowered. the diff needs to be raised. |
PRE would be a good choice
SVPerformance on Sandy does welding. Have a friend who used to work there; they build drift cars.
http://svperformance.net/index.htm |
| All times are GMT -4. The time now is 02:35 AM. |
User Alert System provided by
