-   -   real world mpg frs/brz (https://www.ft86club.com/forums/showthread.php?t=6099)
HotLavaMann 05-16-2012 11:54 AM
Originally Posted by SoFRSnSoClean (Post 214153)
Can the manual drivers tell us what the cruising rpm is at 70mph? I'm still torn between getting the auto/manual as it will be my daily driver and the extra mpg wouldn't hurt. I know the auto cruises at 74mph at 2500rpm which is super nice!
2500 RPM at 74? Damn, that would be nice. Here's from a previous post I made:
"With manual transmission : indicated speed of 60mph is 2600 RPM, 70mph is 3000 RPM, and 80mph is 3450 RPM. That is better than I hoped in that I'm one of those guys that likes an overdrive 6th gear for good mileage and quiet interior at highway speed."
If the auto is doing 2500 RPM at 74 then I think I will consider dropping in the 3.73 rear diff gearing. Sure, it will make all the gears taller but I can live with that. I don't think it will get me to 2500 RPM at 74, probably something more like 2650 RPM at 70 mph but it's closer.
mattles 05-16-2012 12:13 PM
I do 50/50 city highway split and I got 19 on the first tank, and about 24 on the second tank. A bit more highway on the second tank and a bit less hooning too.
GrimmSpeed 05-16-2012 12:39 PM
wow, definitely exceeded my expectations of "real life" as well. Be interesting to see what it does when we start modding/tuning.
Justin
MarkRacerX 05-16-2012 01:47 PM
I saw close to 300mi on 1st tank, mpg was showing 26.9 avg :)
aesthetect 05-16-2012 05:00 PM
subscribed, im really liking these numbers reachin up to the 30mpg range
this will likely be the deciding factor that seals the deal for the BRZ for me, most competitors im shopping get ~20mpg
kensic 05-16-2012 06:49 PM
in my experience so far is that real life mpg for any car isn't far off or exactly how it is rated (assumming normal driving)
the 2-3 examples up top are exactly at rated mpg
with that being said, if your car is rated 35mpg on the highway, doesnt matter how you drive or what you do, you CAN NOT get 45 mph on the highway.
speaking from experience with the cars iv driven and read on what ppl get.
Dark_Angle 05-16-2012 06:51 PM
What size tank are we looking at for this car?
thill 05-16-2012 06:56 PM
All depends on how you drive and where you drive. Lots of highway miles? Much easier to hit EPA numbers for almost every car. Lots of city driving with short trips? Much harder.
And of course your driving style. Keep in mind some of these guys are babying their cars. Once you start winding the engine towards redline and higher RPM's you are not going to get EPA numbers most likely.
Consumer Reports has done extensive testing with city vs highway and the consensus is most cars can meet or beat the EPA numbers on the highway, but it is hard to achieve EPA in the city.
Turbowned 05-16-2012 06:56 PM
I'm anxious to see what I can get with the BRZ. My S4 is rated at 18-27mpg. I averaged 30.1mpg both ways on a recent 80mi. trip; on shorter trips I can get about 25mpg avg. My long-term average over 8,100 miles is 22.1mpg, 1.1mpg better than the EPA states.
However when I can't keep my foot out of the supercharger I'm hovering around 20mpg ;) Not bad for 330awhp, though!
eikond 05-16-2012 07:00 PM
I think you're wrong about that. Some "hypermilers" can get well over 10 mpg more than rated.
My 1998 Honda Civic has 208k miles on it and gets 40 to 42 mpg on the highway.. EPA rating is 34. I don't even try to eek out every mpg.. I just drive it normal.
I don't know about the FRS/BRZ because I don't have one yet.. but I wouldn't be surprised to hear people getting close to 40 mpg if they really work at it.
kensic 05-16-2012 07:46 PM
^^ well those hypermiles are an exception. there's always exception.
but for us normal people. what you see on paper is pretty much what you get IF you dont try to race every car you see.
lol
#87 05-16-2012 07:56 PM
You can easily get more than EPA numbers. My car is rated 31 highway, and that is the mileage I get if I cruise around 75-80. But if I am on a roadtrip I cruise control at ~63 and get over 35.
You can look up the actual test cycle and how much load they put on the engine and stuff. You will see if you have a light foot you can exceed those numbers no problem.
Allch Chcar 05-16-2012 11:09 PM
The 2008 ratings are completely unrealistic. I got the pre-2008 numbers no problem. And when I tried, I exceeded them. :iono: I'm not special, half of it is just paying attention.
I think it's closer to 2800RPM at 70mph. The OD in the AT is over 20% taller.
I would do the taller final drive swap and then sell the stock 4.1 gears. :)
Not bad. BTW, the stock gauges lie. Speedometers always read several percentage points too high. :D
Exactly. 90% of my driving is <50mph. There's no much you can do about long stretches of interstate(without going into advanced tips) but low speed is where the best MPG can be found. ;)
:clap: Were you even pushing it though?
Exhaust 05-16-2012 11:37 PM
Originally Posted by kmbkk (Post 214141)
Until you hit Austin! That is, unless you take the loop around it.
this + infinite. Damn austin to hell.
