| Ganthrithor |
02-28-2014 04:05 AM |
Originally Posted by chas3wba0
(Post 1563685)
I would like to point all the blame at the tires and road oils, but I also can't ignore the fact that it could have been so easily avoided if I straightened out before hitting the gas. I did spend a lot of time trying to break traction in a parking lot the last time it rained hard, and it was tough even in 2nd gear, so I had no idea I could pull this off in 3rd. Agreed, the recent dryness definitely played a factor, though. Tough lesson learned :suicide:
Yeah, surfaces make a huge difference. When it rained down here in Santa Barbara a month or two ago (back when I was still on the Primacies) I took the car across town to an empty parking lot to get some oppo practice in. On the way out and back I took a nice windy back road. On the way out I drove pretty conservatively and was still getting a little bit of slip here and there. When I got to the lot, the asphalt was chunkier than most road surfaces and I had more grip-- you could certainly get big slides going but you had to work at it even in second as you described. When I was done I hopped back on the same road and ramped the speeds / throttle inputs up a bit and was very quickly sliding all over the place. They were smallish slides, but the car was much, much easier to provoke on the smoother, newer surface of the road than it was on the rougher parking lot surface.
It really was quite an unnerving drive home. It was fine because the roads were totally deserted, very familiar to me, and it was a good time to play around with the car. I felt perfectly in control of the car, but it felt controllable in the same sense that you feel in control when sliding around an autox course: it's fine when its an empty road, you're in the mood, and you're on top of the car and doing things intentionally. The level of grip was frighteningly low, however-- the whole time I was thinking, "Holy shit, what if the car was driving like this while I was cruising down a busy street and I had to make an emergency maneuver?" It was literally like driving on snow-- I was sort of doing 20-25mph through corners and any time I used more than ~25% throttle the car would get decidedly sideways in a very un-progressive manner. To keep the tail end in line you had to be very smooth with all your inputs and only use a tiny bit of throttle-- anything jerky would immediately kick the back end out. Pretty fun stuff when you're up for it, not so good when you're trying to get somewhere safely on trafficked roads.
Anyway, don't get too down on yourself. Just think of it as a good excuse to order up some skid pad time in the future! :burnrubber:
