-   Suspension | Chassis | Brakes -- Sponsored by 949 Racing (https://www.ft86club.com/forums/forumdisplay.php?f=59)
-   -   Coilovers or bracing? (https://www.ft86club.com/forums/showthread.php?t=56920)
OnionTou 01-29-2014 08:59 AM
I'm curious what do you guys think is a better step in my car's development?
This is my weekend/spririted driving/amateur autocross/amateur trackcar/2nd car (when my daily driver is unavailable). It doesn't have to be super street friendly/or overly track oriented. Something of a middleground.
So far I've done:
Wheels and Tires (18" Yokohama Neova AD08)
Slotted Rotors (still stock size)
Pads (Carbotech XP12)
Brake Fluid/Brake Lines
Exhaust (Invidia N1)
Right now I'm up for chassis or suspension.
I'm thinking on going for a midprice suspension (around $2000), but I've noticed that for the same amount of money I could do springs, camber bolts/plates (whatever I need to get my alignment right) and brace the heck out of the car (strut tower bars, sway bars, all sorts of bracing).
Oh, and I forgot to mention, roads here are bumpy, speedbumps, potholes, you name it, we got it.
What do you guys think is a better step for an amateur autocrosser?
JDKane527 01-29-2014 12:00 PM
Coilovers, then bracing if needed.
donutfilling 01-29-2014 03:09 PM
Get a well balanced set of coilovers.
Bracing will not make as big a difference and they can be used to fine tune your car alter on.
mrk1 01-29-2014 03:20 PM
Coilovers will certainly make a larger difference but bracing shouldn't be over looked. When done correctly bracing will tighten the "5th spring" of the car, the chassis.
And when I say correctly I just mean the well designed braces not bling factor ones.
CSG David 01-29-2014 05:15 PM
PM'd you back! :thumbsup:
