Clutch peddle loud squeak
Cable would be my first guess, it may have stretched a bit or something. Can you start it in gear with your foot on the clutch?
Using Google translate, it seems this article might be relevant: "Clutch release bearing abnormal noise".
http://ameblo.jp/zn6-86-fa20/entry-12164068390.html https://translate.google.com/transla...-text=&act=url |
This is interesting - will have to try this out.
Didn't realize you can remove that metal part of the transmission.
Hey everyone,
Just wanted to give my success story on this. My clutch began squeaking maybe 5,000 miles ago. I now have 41,000 on my car. It was quiet, but then ended up being super loud, just like in the video of the original poster and probably what most of you are experiencing. Took my car in and explained how others were having the same issue as myself. They seemed to be a little hesitant at first, as the sound somehow stopped squeaking after we dropped it off. We mentioned the clutch fork and throw out bearing, etc. Ended up having the transmission replaced under warranty. My car was in the shop for less than a week. I have the paper with everything replaced on it. Squeak is gone, and my clutch feels like new. Only thing I paid for was the clutch plate, but I didn't have an issue as I saw their receipt after everything was said and done. :0 I went in the dealership expecting to be told it was "normal" but I am very pleased with everyone there. If anyone has any questions, message me and hopefully I can help. This is pretty much my second post here as I have been lurking around hehe. |
@heatherger which dealership did you go to? Can you pm me?
When u had ur squeak sound.. was ur clutch felt crunchy at the end of the trave as well? Sent from my Nexus 5X using Tapatalk |
When inspecting/cleaning my spare yesterday, I saw that the snout and the fork pivot were both caked with clutch disk material that had been absorbed by the applied lubricant. The combination had become a gritty abrasive mess. |
I got call from Dealership today and saying that my tranny need to be parted out in order to find out exact cause and must send to HQ for approval. If HQ deny on warranty (my b2b warrany expired period wise 2 month ago but only driven 38,000 km) ill have to pay off the diagnose and all the fee which they quoted replacing bearing would be 600+ tax. Idk what to do at the moment.
Let me hear from you guys if anyone had similar situation. Thanks in advance Sent from my Nexus 5X using Tapatalk |
Is your car just making the noise and still driveable? I drove mine with the noise for 1 year, 10k miles before I got it fixed. If yours is just the noise and nothing else, then you should try another dealer. Quote:
Bottom line - get in there and clean it all up before all the parts wear even more. It's a gritty mess. |
I put some of Red Tacky #2 grease in there but no luck.(w/o removing the slave cylinder) Thanks |
I guess what I'm getting at is, scare me. :thumbsup: |
I'm still confused. I have this issue. Same as OP. Only happens after the car has been driven for a bit (so clearly something needs to warm up) and it's just a squeak at the bottom travel of the pedal. There is a bit of "crunchiness" in the pedal, but it just matches the creak, as if it just isn't traveling smoothly because something isn't properly lubricated.
It seems for all the world like it is just a lack of lubrication somewhere, and yet tons of people in this thread have had entire clutch assemblies replaced, or throwout bearings replaced. Which is it?!?! Once the car is warmed up, it will make the same noise whether the car is on or off. That makes me thing it isn't the bearing, but what do I know...? |
Imma pull the dust boot off and spray whitr lithium grease follwoing weekend. Will be updating the result! Sent from my Nexus 5X using Tapatalk |
full size image http://i.imgur.com/whwTVMSl.jpg You can see how the lube just melted (dropped) It's sticky like tar. full size image http://i.imgur.com/9CiuCTKl.jpg The bearing itself is in perfect condition; buttery smooth - zero noise. full size image http://i.imgur.com/JKyZP1Ml.jpg You're welcome to come up and check it out for yourself. I haven't touched the original parts. They shipped the fork and TOB with the spare trans so that's what I'm running now. |
Was it poor grease or something else ? Is it common in cars generally ? A nice "How To" with tips would be awesome as I can see myself doing this but not every year :|
So I guess nothing to worry about for now. |
If mine doesn't start squeaking again in a year, I'll still get in there to inspect at least once to see how my choice of lube holds up. I did come up with a couple nice tricks for removing the transmission and I applaud Subaru for keeping serviceability in mind. Of all the drivelines I've done, this one is by far the easiest but it's still a transmission swap. I'm a big guy so my technique involves physically bench-pressing it into place. |
Hey guys. Im planning to put somr lubrication in clutch fork inside tranny.
Slave xylinder need to be removed in order to spray inside pivot point? Sent from my Nexus 5X using Tapatalk |
I kind of wonder if the lithium grease I used cleaned up the grit/tar like lube that you pictured. I know it has some dirt cleaning/grabbing properties.
Nah, just added to the mess. It all cleans up ok.
My squeak returned damnit. All dealership did was spray lube in there rather than replacing anything.
"Nah" two posts in a row does not read well. Nah nah nah nah...
What used to be grease is really sticky; more like rosin now. There is definitely some binding. I guess just keep that in mind and be careful if it seems to get worse. |
Is ure squeaky ever came back after adjusting the engagement point? thanks! Sent from my Nexus 5X using Tapatalk |
Taking my car in for this issue tomorrow. Hopefully they just use a better grease tomorrow or something simple.
It's only been a couple months since I cleaned mine but the clutch is smooth as silk. |
I suppose I should update this thread. Brought my car in for the pedal creaking in the latter half of pedal travel (both directions) - most notably after the car had warmed up a bit.
I brought it in (34,500 miles), told them I thought the throw-out bearing was going bad, and they took the car into the shop and poked around, this is the progression of events: "Sir, it seems like your issue is the clutch. The mechanic thinks you might have a hot spot, which is what could be causing that creak." "Okay, well can you explain to me how that hot spot causes the same creak sound to occur when the engine is off?" *service rep goes away; comes back 5 minutes later* "Yeah, it seems like your throw-out bearing is ALSO going bad. We are ordering new parts." *I take the car back, and come back a week later to have the work done.* End result: I received a brand new throw-out bearing, new pressure plate, new flywheel, and new clutch disk. A different mechanic did the work, and told me that the clutch "showed some wear, but was otherwise fine." So sounds like it wasn't the clutch at all, but instead the TOB. The mechanic told me that the throwout bearing going bad had caused the pressure plate fingers to start making noise too? Not entirely sure. All I know is the clutch feels ENTIRELY different now, and SO much better. It's so much smoother it strikes me just when I get in the car and depress the clutch to start it. Clutch engagement is buttery smooth now, and it just feels WAY better. One issue I had been having was that sometimes when I went to change gears, taking it out of gear was a bit rough and "thunky"... almost as if I hadn't entirely disengaged the clutch before yanking it out of gear. I thought I was just being retarded (this is my first manual) but that is gone now, so I think whatever was going on in there was maybe affecting how the clutch engaged (which would explain why it is much smoother now.) Can anyone theorize and explain exactly what might have been going on in there? One of the reasons I prefer to work on my own car is because I like to understand what was happening. |
| All times are GMT -4. The time now is 11:15 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
