-   -   ProCharger I-1 (https://www.ft86club.com/forums/showthread.php?t=51344)
bfrank1972 11-14-2013 01:23 PM
ProCharger I-1
Has anyone considered building a SC system based on one of these? Looks like it combines the efficiency of a centrifugal SC with a drive that allows full boost at low rpm. You can even control the shape of the boost curve.
http://www.procharger.com/i-1supercharger.shtml
bfrank1972 11-15-2013 08:59 AM
Nobody thinks this is neat? :)
Sent from my iPad using Tapatalk - now Free
Wonderbar 11-15-2013 09:14 AM
It's cool, but would be tough to build for our application since there isn't any support.
bfrank1972 11-15-2013 09:20 AM
Yeah I hear you - just thought I'd put it out there to see what you all thought. It's something I've thought about for years now, centrifugal supercharger with a variable transmission. Lots of low end power, high efficiency, none of the heat/exhaust plumbing a turbo needs. I'm surprised no one has released something like this before - which tells me perhaps there are some hidden downsides (maybe transmission reliability). I think it's a pretty new kit so maybe down the road support for the fa20 will come.
mrk1 11-15-2013 09:34 AM
yet another new product with a lower case "i" in its name
but on a more serious note that looks like a pretty big part, could be hard to fit
ZionsWrath 11-15-2013 09:38 AM
Let procharger come to the game but I doubt it.
ft_sjo 11-15-2013 09:48 AM
So tough that everyone else has managed it fairly easily.
Wonderbar 11-15-2013 09:50 AM
Then build us a kit if it's that's easy!
asher187 11-15-2013 10:33 AM
They are pretty expensive just for the head unit ~2700 no other parts, tuner kits around 5K
Edit: http://musclemotors.com/index.php?ma...&cPath=344_516
bfrank1972 11-15-2013 10:54 AM
Yah I see they're installing it on motors with some room in the engine bays - that said if you get rid of the stock air box there's a good bit of room up front on our motors. I also see that it's expensive, not an entry level kit, but it comes with some shiny fancy electronics to play with and they say it's good up to 900 flywheel hp. And just look at that boost curve :burnrubber: It has a bit of ramp-up, I assume that's when the transmission is spooling it up, but then boost is flat till redline. I for one would like to see what one of these could do on an FA20!
bfrank1972 11-15-2013 10:57 AM
I think they're even more expensive than that - around 8 grand for the full stage 2 kit with the variable transmission. Still, that kit looks like it can produce some big numbers. For the high horsepower freaks looking for big torque, might be attractive.
SixSpeed 11-15-2013 04:30 PM
So basically it's a Centrifugal Supercharger with a CVT built in? (or a Supercharger with Multiple Personality Disorder, your choice) This will be an interesting item to watch, regardless of the price.
bfrank1972 11-15-2013 05:26 PM
Yup that's it - looks like it also has some fancy electronics to control the CVT. I think you can control the boost curve as you like, not sure of the degree of control - it would be neat to have a graded boost curves for 1st and 2nd gears for high power setups.
USMC FR-S 07-21-2017 06:28 PM
I did it.
I just stumbled upon this thread, but I did this setup in 2013. Here is a picture of the engine bay. I'm using the P1SC ProCharger unit. http://i.imgur.com/AlzMwYi.jpg
