-   Issues | Warranty | Recalls / TSB (https://www.ft86club.com/forums/forumdisplay.php?f=72)
-   -   I keep breaking lug studs!!! (https://www.ft86club.com/forums/showthread.php?t=51038)
stevesnj 12-29-2015 12:39 PM
Originally Posted by humfrz (Post 2493237)
Don't muddle up the issue ...... many have already made up their minds ...... :mad0259:
Well it's just info from the Toyota engineers that's all. Not muddling info is it? :thumbup:
humfrz 12-29-2015 01:30 PM
Well, now, you just can't believe everything you read in the owners manual ..... :D
humfrz
pantdino 12-30-2015 01:27 AM
Originally Posted by Sideways (Post 2490153)
Never had any problem with studs on my brz. I use anti seize on my lug nuts too, but not every time I remove my wheels and I only use a very small dab of it. .
I think that's the solution-- don't slobber so much on the threads can't grab, but just enough you can't get rust / chemical seizure between the metals.
There are numbers for how much you should decrease torque for a "oiled" fastener-- it's about 25%.
I use 70 ft-lbs and sparingly anti-seized lug nuts.
pantdino 12-30-2015 01:34 AM
Originally Posted by Nickosport (Post 2492298)
I'd like to add that anti-seize is not a lubricant; its an abrasive.
So all of that BS above about lubricated vs. nonlubricated torque in this particular situation means precisely squat.
This makes a lot of sense- and explains why I have never had a fastener on which I had applied anti-seize come loose.
The owner's manual says to not use OIL or GREASE on the threads. Anti-seize is not on the list.
