Cybmx: sprint has different sized pads (for example - much thicker). As sprint front BBK is braking bias-matched to stock rears, imho better to install same compound pads on all corners, - stock sized in rear, - this kit sized in front. You may use different compound pads in rear, but it will certainly change brake bias, so imho better not. As it's mostly front that does most of braking, rear pads need to be exchanged way less often. For fronts you'll really enjoy cheaper pad prices and thickness of chosen pad sizing that will let pads last longer.
Thanks guys. I have the sprint kit with a few set of AP c300 pads, where should I go to purchase the matching pads for the rears? |
Would you be able to recommend me an alternative? Thanks a whole bunch. |
The Carbotech RP2 is somewhat similar, but has a bit more bite. |
@CSG Mike @JRitt do you guys find that the caliper grabs the rotors pretty hard on fresh pads? I've done one track day on a new set of ds1.11 and my alignment guy (who races) made a comment that my fronts might need a rebuild given how tight they were grabbing and that the piston seals might be cooked. I'm skeptical since I've only really done perhaps 6 track days on the brakes... Although they were tough to push in when swapping the new pads in
Sent from my SM-N920W8 using Tapatalk |
For the guys that drive the car year round and weekend warrior the car, I usually recommend servicing the calipers once a year. |
| All times are GMT -4. The time now is 02:02 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
