-   DIY (Do-It-Yourself) Guides (https://www.ft86club.com/forums/forumdisplay.php?f=43)
-   -   Installed/How-To: 2014 Forester XT OEM Oil Cooler(pics!) (https://www.ft86club.com/forums/showthread.php?t=50427)
ft_sjo 11-04-2013 04:35 AM
Originally Posted by LeeMaster (Post 1311091)
why the hell Subaru didnt do this in the first place
Cost, and it's not necessary for a stock vehicle.
s2d4 11-04-2013 04:50 AM
Originally Posted by imom (Post 1310523)
I still like to get get the full part number of the BRZ water bypass pipe in case I need to buy it.
Neither of the options you are looking at require the brz pipe.
If going with a new pipe, much easier to cut the mentioned pipe and bead form it, done, no more kinks and cheaper too.
PantsDants 11-04-2013 05:14 AM
Couldn't you just use a longer section of hose and zip-tie it somewhere to prevent it from kinking?
imom 11-04-2013 05:14 AM
A picture would be nice to show what you mean... after seeing Kostamojen idea, I may not get the BRZ pipe and just get the rest and wait and see how to plumb the oil cooler.
s2d4 11-04-2013 05:20 AM
In the picture where you have the "outlet?", it's the bend pipe right next to it and points to fig 72.
Therefore, cut + bead form = no more bend = no more kinks when using original frs/brz hose.
Anthony 11-04-2013 05:27 AM
Subscrizzled my nizzle.
CARNZ 11-04-2013 09:30 AM
Here's a pic I took just now from the topside of the engine, you can see how slightly bent the BRZ hose is when installed on the FXT pipe.
https://scontent-a.xx.fbcdn.net/hpho...51747111_n.jpg
I have no worries about the long-term effects of this as the kink is very very small. I could bend the FXT pipe upward some and completely eliminate it, but like I said, no worries.
xxscaxx 11-04-2013 01:01 PM
Depending on how large that pipe is, i'm going to use my hand pipe bender to straighten that part out if I can. if not, no biggie.
Superhatch 11-04-2013 01:01 PM
Originally Posted by CARNZ (Post 1309142)
I'm gonna see if I have time today to do some logging with BRZedit during hard driving.
Realized I forgot to list the part number for the FXT water pipe - 14050AA970...
Ugh my mistake
FWIW that part from my dealer is 76.20...so it adds a bit to the total and puts the cost closer to $350.
CARNZ 11-04-2013 01:29 PM
If you order it from heuberger its cheaper. I posted their prices for everything in a screenshot above.
$260 and change for everything
Tye300 11-04-2013 02:41 PM
Is this the Forester XT inlet and outlet connection and what CARNZ had used for the BRZ set up? As shown in the first attachement from Kostamojen's picture?
Thank you Kostamojen for your proposal... your way seems to save the cost of getting another water bypass pipe
Kostamojen's water routing for the oil cooler picture (second attachment)
Running it this way seems a lot simpler.
CARNZ 11-04-2013 02:51 PM
I was considering that way at first as well, my only concern was if it would possibly cause a hinderance in coolant flow.
The oil cooler inlet is the same size, but the outlet is smaller. Also, all the other coolers are plumbed in with extra piping/lines, maybe Subaru thinks there wouldn't be enough coolant flow to run everything through the cooler instead of each having their own coolant feed.
All speculation, but thats why I ended up buying the pipe and adding the fitting to get the coolant from an additional spot for the cooler.
Kostamojen 11-04-2013 03:07 PM
FYI that was just an early idea. I ruled it out because the heater hose is much larger than the oil cooler lines.
There is another option other than the FXT return hose for manual transmission cars, and that is the coolant crossover pipe on top of the engine that has a blocking plate that can be replaced with a plate with a fitting from the AT cars so you can run the return line directly to there. It might be cheaper, don't know.
Tye300 11-04-2013 03:13 PM
Noted. Well it was too simple to be true. Haha.
