-   DIY (Do-It-Yourself) Guides (https://www.ft86club.com/forums/forumdisplay.php?f=43)
-   -   Installed/How-To: 2014 Forester XT OEM Oil Cooler(pics!) (https://www.ft86club.com/forums/showthread.php?t=50427)
sickmint79 05-14-2016 07:39 PM
Originally Posted by mb_ (Post 2647747)
Went to the Ridge Motorsports Park yesterday in Shelton, WA. Oil temps were at 100 degrees celcius (Total 0W-30) during and after each session. But then again, it wasn't every warm. We'll see what the temps are at in a July track day.
any more days yet? 100 c is quite low!
Tor 05-15-2016 09:44 AM
@Kiske, what was the result of the install? Does the oil still heat up faster even with an external oil cooler installed too?
Is the Mishimoto 288 plate thermostatic?
Originally Posted by Kiske (Post 2250227)
I called Mishimoto who has a new oil cooler setup for their 2015 WRX that works WITH the OEM WRX/Forester oil cooler setup. They (though customer service) let me buy just the adaptor sandwhich plate and threaded center bolt/nut for $15+shipping that fits onto the OEM style oil-cooler, clearing the larger anti-spill ring around the oil filter.
Here is the part numbers... or what is on my invoice for the bolt and sandwhich plate.
-Mishimoto 288 Kitted in US $7.50 Extended: $7.50
-Mishimoto 1020 Kitted in USA to make MMSPA-M20. M20 x 1.5 -- M20 x 1.5 (no dashes) w/ zipper poly bag. $7.50 Extended: $7.50
Will let you guys know how it goes. Hope to have the parts by next Wednesday. :)
Kiske 05-15-2016 01:25 PM
No, it heats up about like it did when it was stock. In the 20 degree winter mornings it takes a good 4min of light driving to get the temp up to around 115*F.
In the spring and summer it heats up like normal. If the car isn't moving (like let it warm up in the garage) the effects of faster warming isn't really noticible to me anymore. It feels stock Keep in mind I have a larger radiator, low temp thermostat, a large 19row oil cooler, about 15% more incoming air into my engine bay and my gauge won't read temps below 100*F unless I'm watching with ecutek, and I haven't in a while.
There isn't a thermostatic plate. You won't have enough clearance to run it, the oem cooler and the oil cooler sandwhich plates and still fit the oil filter without smacking the hood.
Tor 05-15-2016 02:26 PM
The reason for asking is because I just installed a 13 row cooler on my naturally aspirated stock engine car. Even when I when I beat on it, I don't get more than 200 deg F.
So I was thinking about combining the heat exchanger with the external cooler. The heat exchanger to make sure it doesn't run too cool on the streets and the external to keep it from running hot at track days.
But since the oil is going from the heat exchanger directly to the external cooler, I am wondering if any effect the heat exchanger might have immediate would be countered?
In other words is it worthwhile?
mynameis940 06-17-2016 11:52 PM
Hey if anyone is interested I have everything needed for this in my closet. I bought it then decided to sell the car. I'm going to post pictures and stuff in the market section this weekend but just thought I'd post here for now.
Irace86 06-19-2016 02:50 AM
PM sent.
Irace86 06-21-2016 04:43 PM
Sounds like this is a good setup for anyone because it helps warm the oil faster, and acts as a regulator by distributing heat out among the system. Sounds also like it will maintain oil temps just fine for most applications.
The point that I read is that the stock coolant journals throughout the engine don't pull enough heat off the oil, so this oil cooler provides a mechanism for getting that accomplished. And the idea is that spikes in temperatures in any one area (fluids, chambers) can lead to engine failure, so distributing the heat out will allow for safer engine use at high thresholds.
The other point is that this kit doesn't increase the thermal capacity of the system because there is no addition of cooling surface area. If heatsoak was an issue then a larger radiator would be necessary. In the case that the oil regulator couldn't extract enough heat, and it was a bottleneck in cooling (coolant temps were ok, oil temps were heat soaked) then a dedicated oil cooler would be necessary. The good thing is that OEM oil regulator could work in conjunction with aftermarket oil coolers with the addition of a sandwich plate like with the Mishimoto example. In either case, with a radiator or with an aftermarket oil cooler, the system has increased its thermal capacity through the addition of more radiators/cooling surface area.
Irace86 06-28-2016 07:29 PM
Installed the oil cooler. I decided to cut the xt pipe at the curve and weld the end back on so it was straight. Then I painted it with high temp paint. Worked perfectly. Ignore my amateur MIG welds.
http://i280.photobucket.com/albums/k...psmeqefm0y.jpg
http://i280.photobucket.com/albums/k...psxlmqnih2.jpg
I used the same ebay nipple as another member.
http://i280.photobucket.com/albums/k...pse4lbmykj.jpg
http://i280.photobucket.com/albums/k...ps6arpjdfz.jpg
ZZT86 06-30-2016 08:21 AM
Nice job, well done ;)
jcw99 06-30-2016 09:08 AM
Ditto
j_motion 07-04-2016 08:19 PM
Can any one verify if the barb on the TB is 1/2 or 3/8?
I am going wit the TB route, just want to make sure i get the right size hose
thank you
Roberto12 07-05-2016 09:06 AM
https://goo.gl/photos/nAomQwmNrGLmHBh3A
https://goo.gl/photos/fXTgxowjS5yEgySK7
I have an external oil cooler and the OEM together. It does not smack the hood.
CxG 07-05-2016 03:07 PM
Does the oil warm up during winter?
Sent from my D5803 using Tapatalk
Roberto12 07-05-2016 09:35 PM
Yes it does. It also keeps the oil warm enough so that it doesn't run to cold in the winter.
