Thank you so much dude!!! Your help is appreciated so much!!!
I'm now 100% ready for the install. Start tomorow morning! |
It's a cake walk @grostoine. Just take your time and let it come together. The hardest part for me was getting the oil reservoir mounted. You'll need to release the brake line from the plastic clips from enough locations to raise the line without damaging it.
Seriously Kraftwerks... WHAT an awesome kit. Easy installl WOW !!!
Miss the A/C cover doe.... |
I was missing the belt cover as well and hear its shipping out tomorrow. I'm curious if you had any issues getting at the bolt under the brake line. Did you purchase a KW tune? If so what do you think and when is your dyno going to be up :). I should have the results of the @Drift-Office tune on this kit no later than Saturday |
Whew! Order finally paid for and should ship today. Really, really looking forward to your results @digital_assassin ... I'm going to push the install until after the new year. Going to fly my tuner in because I'm running a FlexFuel kit
My car is stored until April so I guess I won't know how it goes until then. I did not purchase the KW tune because I lost my job and I made everything that I could so I spend less money... I had engagement for the kit and really want it but the tune can certainly wait for the moment... Plus I had to change my headers :( I can't wait on your result's ! |
Bob @ Drift-Office, LLC |
I purchased one as well. The compressor outlet looks to be in the correct location so maybe that was just an issue with some? May start the install Sunday. Good advice in this thread!
Added you to the owners list @dren. Can't wait to see your results!
Digital assassin, what are the results? Did the kit made less, equal or more power than the jr kit in the oder thread?
We shall see tomorrow. No posting happening until I pick it up.
And the results are in!
http://www.ft86club.com/forums/attac...7&d=1387071025 |
It's been bugging me that both kits instructions don't address this. According to Rotrex the Oil Reservoir should be lower than the Rotrex. The KW kit location can be worked to achieve the proper positioning with a little work. Had to bend the bracket a bit and then bend the tab holding the molex plug out of the way. I don't know if this is an issue or not but I changed mine up just to be safe.
http://i1144.photobucket.com/albums/...pso7bwiyl6.jpg Look by the battery and you can see how high it was. http://i1144.photobucket.com/albums/...psmkbc9say.jpg So I lowered it waaaayyy down. http://i1144.photobucket.com/albums/...pshixsgozf.jpg I'm interested to see if it is in this position that maybe it will actually flow oil. I can't start the car tonight since the kids and neighbors are asleep :) |
Digital Assassin...the oil reservoir in the original KW location is fine...Rotrex is concerned that too high of position will cause the front seal to leak due to high static hydraulic pressure; their generalized instruction to mount the reservoir lower than the charger guarantees that the seal will not see high enough static hydraulic pressures to cause leakage. The reservoir even or slightly higher than the charger with the line running lower (as is the case with the KW kit) is fine.
@gmsii
How long before the toothed idlers come out? Only - I read or hear about is noise levels and I'm very curious is those bits being toothed will basically solve that or not. I'm abit of a nancy pants with additional noises so this is a concern for me. |
Received my kit the day before last... smooth idler pulleys. So, the toothed idlers have not come down the pipeline just yet.
Next tip guys.
The cold side piping that runs behind the passenger headlight needs to be checked after installing the headlights. I was hearing a bit of rattling and chased it down tonight and discovered when I reinstalled the headlights I had sandwiched the IC tube in between the headlight and the attachment point of the front crash bar and if left unattended would have wore a hole in the IC pipe. http://i1144.photobucket.com/albums/...psnqwjpk2i.jpg After reinstallation of the headlights check this side and make sure you still have clearance. Now that I loosened things up and moved them the issue is solved. Not a problem with the kit just something to be aware of when aligning things. |
Anybody else get their kit installed yet or am I still the only one getting to enjoy this thing so far?
Which injectors and fuel pump did you go with? I think we were about hitting the limits of the stock setup so this may open up some more potential in the tuning for you. Colder spark plugs should help too.
The "other" kit includes a bunch of these pads for the exact same reason. |
May as well change out the spark plugs at the same time... good call. |
I used the rubber liner on every spot where the fitment was tight. Doesn't hurt, since I HATE rattles and funky noises. |
When I saw that the oil for the SC was $100 I sprayed coffee all over my phone. Now I'm typing from my laptop.
Good LAWD that stuff is outrageously priced! Must be made of Unicorn piss or something. |
You have to change it every 80 k miles or two years. Its not THAT bad
Wasn't much tho. |
I'm installing mine now after I received my EcuTek in the mail. I had the same issue with the idle pulleybolt hitting the oil filter. I took a hack saw to it and it fits fine now. The first issue I had was the main crank pulley was too tight to fit over the adapter. I threw it in the oven on 250 or so and pulled it out and it fit just fine, so there is a bit of an interference fit on mine. The oil reservior is a PITA to install. It does help to have everything hooked to it before you install the bracket. I had to man handle the brake line as well.
The pulley adapter is a snug fit for sure. I used a soft rubber mallet and gently tapped it on. I was worried it wouldn't move to align the bolt holes but to my surprise once it's seated you can still rotate it to the correct orientation relatively easy. Good call on shrinking it with heat though!
Cold causes contraction, heat expansion. |
@KraftWerks : Did you send the A/C cover yet?
Just a heads-up... received my replacement parts today. Includes the AC belt cover. |
I threw mine on a week ago. Nice touch.
I didn't receive my cover.
The piping in a few areas fit tight. I may go back and use some rubber. One thing to note, I screwed up and cut my vacuum line too close to the brake booster. There apperantly is a check valve or something like it in the line. I yanked it out so I could get the T to fit. You can feel where the valve is by squishing the line. I wish I would have known that ahead of time. I don't know how important that thing is, I may need to purchase a new vacuum line from Subaru. Anyone have any ideas??? And the last issue I had was the EcuTek shipped without a license! I installed the SC all day Friday and by the time I had the EcuTek set-up it was almost 8pm here, which is 5pm in Cali and I couldn't get a hold of the tuner. I got an email from Kraftwerks saying I need to call him to get the registration finalized. Wish I would have known that sooner... The car still sits. Oh, and a final note, make sure that you have the oil reservior rotated the right direction before you install it. I had to take mine back out and rotate it. |
Sorry for your trouble but I'm definitely making a note to check this line when I get to that step. |
| All times are GMT -4. The time now is 10:19 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
