Hey guys I know it's beating a dead horse here. I read this thread top to bottom. My question is how often are we supposed to check tension. I've been checking every day at cold starts
Some days it's super loose. Some days it's tight. I live in NY so idk if the humidity has anything to do with that. Anything helps. Thanks. Sent from my SM-G988U using Tapatalk |
I live in Kentucky and have massive temperature swings as well. I was super paranoid about checking my tension after every trip but as I grew more accustomed to my blower, I check it a lot less now. I can hear the differences between when it's too tight or if it's getting too loose. My car is a DD that sees a lot of stop/go driving, so I don't get many chances to give it hell and have had pretty good luck on keeping the tension where it should be. I may check it now before a long trip or afterwards, or perhaps every other week unless, like I said before, it starts to sound different and I get belt flap. In my opinion there's no right or wrong amount of times you can check to make sure it's properly tensioned. These are big investments with severe consequences if something goes wrong, so if you want to check it every 1hr, then so be it. Hope this helps. Doc |
too tight, you'll wear our the bearings in the pulleys causing the pulleys to wobble. in turn, will cause incorrect belt wear OR snapping the supercharger pulley bolt. so you'll need to get new pulleys, new belt and possible sending in your supercharger for repair for the sc main pulley bolt. too loose, you'll end up with the same issue. this kit is absolutely complete garbage and absolute trash. I've had this kit in the early days of ownership of my car and I HATE that people STILL buy this kit. do yourself a favor sell this POS kit and buy yourself a jackson racing supercharger kit. this kit is literally so bad, i am SHOCKED they still sell these too poor folks who don't know any better. It isn't fair and I hate seeing people buying this kit still and then run into issues, only to be backed up (or not backed up) by non existent customer service.... I wish an admin or mod of this thread would just block/delete this thread because of these reasons.... good luck, if i were you i'd sell this kit and buy a jackson racing superchareger kit if you want a supercharger... |
Actually Joell at Kraftwerks has helped me alot. And I've had the kit on for about 4.months no issues. Tension has been the same. This is with hard pulls and mountain runs. Tension and belt hasn't skipped a beat. I was asking because of what I read on the forums. I'm guessing people were over tighting and that led to the Kraftwerks kit getting a bad rap. Put this in perspective.
5 months no issues and I blew 2.coilpacks. lol Attachment 205437 Sent from my SM-G988U using Tapatalk |
I live in NYC. Crazy temp swings . I have a track day coming up soon and I'll keep y'all posted. But bear mountain isn't a slouch lol
On the topic I was thinking of making an auto tensioner system for these kits, would anyone be interested in something like that? |
Posting an update. Still no issues. Modlist is
Deatschwerks 700cc injectors @Xero-Limit flex fuel kit Kraftwerks Supercharger with track pack Custom oil cooler Open flash header Generic over pipe Berk Front Pipe Invidia Q300 ACT 6puck Lightweight flywheel https://uploads.tapatalk-cdn.com/202...c429f954d1.jpghttps://uploads.tapatalk-cdn.com/202...e0cfb3d7a1.jpg Sent from my SM-G988U using Tapatalk |
Need help
2 Attachment(s)
Pulley that’s connected to the unit head keeps snapping off, this is the second time this has happened . Any ideas ?
I am trying to get support and opinions on this rotrex blower. It makes this noise at idle and I can hear it even with the hood down. I am possibly going to purchase this kit for my car and I wanted to know if this noise is considered normal for a rotrex?
https://youtube.com/shorts/ssCGJgzyAlo?feature=share |
It's hard to say from the video but it kind of does in a way. The video seems to sound too metallic in the beginning but when closer to the filter it sounds better. Best thing to do is find one in person at a garage or car show, IMO. Centrifugal superchargers are for the most part quiet inside the car when driving and when compared to other superchargers. They do make a little more rougher noise at idle though until you get up to around 2,000-3,000RPM and then they start sounding good. When punching it and at full acceleration you'll get a beautiful and distinct whine out of it. My Kraftwerks C38 makes a slight "gear" noise at idle from the belt turning the gears (not the head unit impeller) but it's low and it does make a vacuum cleaner sound where it's sucking the air through the filter. Overall, it should not be too loud or screeching at idle. A lot of the complaints you see on here are when someone has the belt tension way too tight. I've had my kit now for almost a year and have never had any problems with it, or the tension once I learned to set it correctly. The instructions say to set it at a certain length but they're outdated and wrong (unless Kraftwerks have fixed the issue.....I doubt it, though). Mine is set to almost double what the instructions say at 29.7mm and it sounds great with no belt flap. It's also stayed there without me having to adjust it every day, like some reviews say. I'm rambling on but just so you know this is a great kit and looks beautiful on the car. May I also suggest Zach at CounterSpace Garage to do your tuning. The man is a god and helped me to not blow my car up after multiple engine mods. :party0030: |
I've done this and my KW C38 kit has been happy as a clam! |
Hey guys, looking to see if I can get any assistance. Just installed a low miles c38 kit I bought from a member. Install was fine and it runs well. My tuner is using OFT to tune it on 91 since I can't afford ecutek at the moment and still running stock injectors, clutch etc. We're having problems where this c38 will want to go beyond 12lbs before redline so it bucks. I have the datazap here:
https://datazap.me/u/sawvyeej86gmail...og=0&data=1-10 What size pulley does the standard c38 come with? What size is recommended to stay at 10lbs? Would like to hear some replies before I take her off again. Thanks! |
Standard C28 rev 2 and rev 3 are 95mm, the first revision is 90 I think... Not sure what is going to keep it at 10psi, not sure if there's a larger pulley :O
Idler Bolt
2 Attachment(s)
Supercharger and belt still running good. But having an issue with the Idler pulley backing out. The Idler pulley bolt snapped. I replaced it with a longer Bolt, Placed white out on the tip of the bolt and test drove it for about 5 mins. I noticed that the bolt again backed it self out slightly. How tight is tight with this idler bolt and and tips on keeping it tight? Like everyone else, this would be the perfect kit if the tensioner was automatic lmao
^not sure if you already fixed it but the threads on that part look pretty messed up. That might be the reason why it backs out under load. The longer bolt might be bottoming out and not holding the idler pully tightly.
1. check the threads. 2. get the correct bolt length. Like most people, I ruined my first C30 due to the improper belt tension instructions and also had the pulley fall off because I didn't use lock-tite. After leaving the belt on the looser side of things, I have had no issues in hot or cold weather. Easy $2000 mistake. |
I know this is a longshot. but does anybody have this part that they want to get rid of. Spare or otherwise? Was doing some maint. and saw that when my bolt snapped it turned the mounting plate into some trash.
California referee smog check?
Anyone in California pass a referee smog check with this kit? If so, any tips and tricks?
Tunes for kraftwerks c-38 kit for 2017 BRZ
Looking for information on where I could get a tune for the kit. I want to purchase the kit and do the install however I have not been able to find anything related to a base map for it.
Sent from my SM-S908U using Tapatalk |
Does anyone know what the difference is between the 13-16 kit and the 17-20 kit? Would you be able to get a 13-16 kit fit a 2018?
I asked this same question to Kraftwerks, and they just came back with "Intercooler piping is different" which I figured, but didnt answer my question on if it would fit. I dont mind cutting or making a few modifications to get the piping to fit...I just dont want to have the intercooler pipes sticking out the side of the bumper or something lol |
the front bumpers are different and thus a slight modification will be needed in my guess with piping
Sent from my Pixel 6 using Tapatalk |
Unfortunately, the Rotrex unit was be bad and seized up. The metal fins busted and made their way through the intake tubes, intercooler, and tiny pieces somehow made it to the throttle body which threw multiple codes in my car. Got burned buying used trying to save a few bucks :bonk: |
| All times are GMT -4. The time now is 10:18 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
