Belt Tension[Why does my belt keep snapping]
So first post here and disclaimer this is what I found researching and looking around i don't claim to have it 100%] but figured id see if i could help some folks out.I recently supercharged my BRZ with a kraftwerks c30 and some other goodies to back it up. I bought a used kit and my belt already had some mileage on it and sure enough my belt went wanted to be as dialed in as possible so did some digging . Below are some checks i've read and consolidated.
[To start out] Press pulley in with your hand until belt is taunt in all locations hand tighten the tensioning bolt then give it another 1/4-3/4 turn. This should put you close maybe a little loose as a starting point [Gates App] Place your finger on the belt right in the cutout at the Y bracket on the SC bracket. Then "twang" the belt with your finger consistently 4-5 times and aim for 50-60Hz [KW Support-CJ] LARGE shout as Kraftwerks customer support is amazing to work with. CJ knows his stuff and will work with you. Everything I needed i got right away shipped the day requested. CJ also helped me by giving me the rough guide below [ note nothing offical here and wont work for everyone] refreshing to say the least. [New belt]17mm from the back of the tensioning bolt to the SC plate [After belt gets streched out a bit] (maybe .5-2 month just check your tension every once in a while when its new) tighten down to between 15-13mm depending on situation. Found that when i used all these methods these rough measurements provided looked to be spot on. [Belt Twist] This one was my Favorite grab belt at same location as gates app move your hand slightly towards the drivers side (middle of longest portion of belt) and twist the belt 90 Degrees. If you can twist it to 90 your good if not too tight if it goes past 90 to loose. It seems strange but give it a shot. All four of these and my SC sounds amazing quite but still present seems to be no tension issues so far. Hope i could help |
2 yrs on the same belt sent by KW with revised pulleys - set it once back then and never touched again.
I used the belt twist method to tension the belt.
I hope this hasn't been asked before.
I am likely moving into this kit and I'm at 70k miles and just want to know about the clutch. I got a stock clutch that is fine as far as I know with gentle driving 90% of the time with the occasional drift day. So I am worried about having to replace the clutch after I put the sc on or will I be okay for a bit? I know a lot depends on how I drive, I just want to ask if the added power will accelerate the clutch going out. Thanks for any input! |
you'll be fine, especially if you're running pump and don't abuse your clutch
Sent from my SM-N920V using Tapatalk |
Picking up my kit from 86Speed in the next few days. im going with a tune from Delicious tuning as well. Does anyone know how much boost I should be safe with running completely stock everywhere else (clutch, internals, injectors, etc)? Question #2: am I okay running without an oil cooler if im just DD around town? I am getting the Skunk 2 Radiator with it and was wondering if that would suffice for your everyday spirited driving. TIA
Do not get the skunk 2 radiator. If it's the one with the built in oil cooler, it will require a lot of cutting and custom work. I don't use an oil cooler on mine and I just take it out in the summer for cruises and blasting around lakes up here. Everything else you should be fine. I think the boost is supposed to be around 9 psi? Been a while since I've looked |
im not sure if it is or not. 86Speed just said it came with the kit as a freebie. Im not one to complain about free stuff lol. Ill have to look into that a bit more. Thanks for the heads up
I believe its just the regular radiator without the built in oil cooler. The one with the oil cooler looks quite a bit thicker. is that what your reffering to with cutting? |
Yeah the one with the oil cooler. The non-oil cooler one I have no personal experience with nor have I seen any threads on. |
Thank you very much for the detailed response! I have full faith in the guys at delicious to give me a good tune. Im just hoping i dont come to regret getting this kit. There are a ton of people on here that bash the hell out of it. :( |
What requirements are needed for this install? Like Injectors, fuel pump, etc
Just finished all 290 pages of this thread. Picked up a BRZ with the C30 kit, had latest pulleys and new belt installed yesterday when I bought the car. Has anyone made a video of setting belt tension? Would be super helpful if someone were to do so!
Thanks |
Read through the thread or search as it's been answered numerous times. If you plan on c30 with no high boost pulley then you'll be fine stock everything. The clutch will probably eventually go. Anything else like high boost pulley, c38, e85, etc. You will need a fuel pump, bigger injectors, and a clutch. |
clutch - replace after (and if) the OEM goes while you still own the car. If I recall correctly I have not read threads when people street driving their cars with centrifugal SSs had to replace their stock clutch because it died. Most folks replace theirs because of suggestion like above (opinions, which are based on what?) or suggestions from shops/tuners (there's the ones making money off of you). |
Thanks pgrandberg11
I had no idea Kraftwerks provided a BOV for this kit. Does anyone on here run it? would you recommend it?
I was referring to the one that was shown on 86speeds website. I saw the Kraftwerks one and a Turbosmart one. I just assumed they were upgrades or different sounding BOVs. |
http://www.86speed.com/performance/k...blowoff-valve/ http://www.86speed.com/new-products/...blowoff-valve/ (this one comes with the kit) I don't think I'd recommend the large BOV since it states that it should be used in applications with 18+ psi. If you're not running enough boost, you'll never be able to completely close the valve. I'd just stick the standard one. The standard one is actually pretty loud in my opinion especially if you let off after hitting redline... |
ahhhh ok. I was under the impression that the "standerd one" you linked didn't already come with the kit. Im waiting for my setup to come in the mail this week which is why I wasn't sure. You tha man for answering so many questions here! |
I just wanted to give a shout out and huge thanks to CJ @KraftWerks
As I was looking to purchase a car with an SC in it, he was extremely helpful answering all of my questions, and went above and beyond in helping us sort a few things out in an unbelievably tight timeline. I don't expect companies to provide this level of customer service anymore. Well done! I'm really hoping they release a DIY video regarding belt tension, seems like it would alleviate a lot of the stress around this system. |
It really doesn't get any simpler than this explanation from pgranberg11.
"Use the half belt twist method. There's a little cutout on the bottom of your supercharger plate that you can't fit your thumb through. Try grabbing the SC belt and twist it half way. With your right hand, put your thumb on first and put your pointer finger on the back of the belt push up on your thumb and pull down with your pointer finger until the belt twists half way." The stress regarding this system will be there for a while until more owners testify to having no problems than when the system first came out. I was hesitant to purchase this system, too, but the price and how "clean"/ OEM the setup looks won me over. We'll see how reliable this kit is in the long run. I did purchase a spare belt just in case. The other SC I considered for this was the Cosworth kit, but I didn't want to spend that kind of money since I have my car getting a V8 swap. Two car projects running simultaneously puts a hurting on the budget. |
Just bought this kit!! Coming in by the end of this week and installing next Monday. So excited! Any tips on installing the oil reservoir?
https://www.mrosupply.com/synchronou..._gates-rubber/ In regards to stress, I believe people tend to make it a lot more worse than it really easy. Honestly, the biggest pain in the ass with this kit was figuring out the belt and the oil cooler setup up (if you plan on tracking, not necessary if you don't). But once you figure out the belt, the kit is nice to drive. |
good luck and enjoy the boost! |
Sounds good. Going to install at my shop with the mechanic I work with. But for the placement of the reservoir where did people install them? Ive seen people with it in the front in the middle by the bumper. Any reason why it would benefit from being located there instead of being by the battery?
[ame="https://www.youtube.com/watch?v=AeyqWWKE7b8"]Kraftwerks. Priming Oil System - YouTube[/ame] |
"The oil lines and the oil system components (filter, canister and cooler) must be placed below or level with the supercharger shaft" and "To prevent oil leaks it is of utmost importance that the oil cooler, oil filter and the oil canister with its cap are placed below or level with the supercharger shaft." |
is there any kind of guide for regular maintenance for this kit?? Like how often belts should be changed, fluid intervals, etc?
| All times are GMT -4. The time now is 10:19 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
