Tunes are calibrated for specific map sensors. The one that comes with the kit is fine, it's just that their revised tune was made around their map sensor (the red one). Get the wrong map sensor for the tune you have and the car won't even idle, just like what happened with my car when my map sensor failed.
Any tuning shop here in Deep South TX can install and tune this kit? Thanks in advance.
The paperwork that came with it described it as "MAP Sensor, Hondata, 4 Bar K S". Not sure what the Denso MAP Sensor that came with my original kit is spec'd at. |
Koyorad with KW kit?
I just wanted to see if any of you used this radiator with the KW and/or ran into any fitment issues, I am about the pull the trigger on the radiator before ordering my KW kit and wanted to hear your opinions |
may the schwartz be with you.... |
I will probably upgrade the oil cooler and radiator before the kit, so it will be ready to use for track ..once I install them I will report back :)
I though people were getting adequate cooling out of the stock radiator. Oil is an issue but water was fine.
sent from your mom |
I tend to forget how hot it was living in the furnace. Man I don't miss that place at all. Except for a few restaurants like Aunt Chiladas, Papa Deux, Fajitas, and the AZ staple (Insert name)bertos. Other than that the heat just kills me now every time we go back to visit family which for whatever reason always seems to be in the middle of the summer.
http://www.ft86club.com/forums/showp...51&postcount=1 Quote:
| All times are GMT -4. The time now is 10:19 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
