I live in NYC. Crazy temp swings . I have a track day coming up soon and I'll keep y'all posted. But bear mountain isn't a slouch lol
Sent from my SM-G988U using Tapatalk |
On the topic I was thinking of making an auto tensioner system for these kits, would anyone be interested in something like that? |
Posting an update. Still no issues. Modlist is
Deatschwerks 700cc injectors @Xero-Limit flex fuel kit Kraftwerks Supercharger with track pack Custom oil cooler Open flash header Generic over pipe Berk Front Pipe Invidia Q300 ACT 6puck Lightweight flywheel https://uploads.tapatalk-cdn.com/202...c429f954d1.jpghttps://uploads.tapatalk-cdn.com/202...e0cfb3d7a1.jpg Sent from my SM-G988U using Tapatalk |
Need help
2 Attachment(s)
Pulley that’s connected to the unit head keeps snapping off, this is the second time this has happened . Any ideas ?
I am trying to get support and opinions on this rotrex blower. It makes this noise at idle and I can hear it even with the hood down. I am possibly going to purchase this kit for my car and I wanted to know if this noise is considered normal for a rotrex?
https://youtube.com/shorts/ssCGJgzyAlo?feature=share |
It's hard to say from the video but it kind of does in a way. The video seems to sound too metallic in the beginning but when closer to the filter it sounds better. Best thing to do is find one in person at a garage or car show, IMO. Centrifugal superchargers are for the most part quiet inside the car when driving and when compared to other superchargers. They do make a little more rougher noise at idle though until you get up to around 2,000-3,000RPM and then they start sounding good. When punching it and at full acceleration you'll get a beautiful and distinct whine out of it. My Kraftwerks C38 makes a slight "gear" noise at idle from the belt turning the gears (not the head unit impeller) but it's low and it does make a vacuum cleaner sound where it's sucking the air through the filter. Overall, it should not be too loud or screeching at idle. A lot of the complaints you see on here are when someone has the belt tension way too tight. I've had my kit now for almost a year and have never had any problems with it, or the tension once I learned to set it correctly. The instructions say to set it at a certain length but they're outdated and wrong (unless Kraftwerks have fixed the issue.....I doubt it, though). Mine is set to almost double what the instructions say at 29.7mm and it sounds great with no belt flap. It's also stayed there without me having to adjust it every day, like some reviews say. I'm rambling on but just so you know this is a great kit and looks beautiful on the car. May I also suggest Zach at CounterSpace Garage to do your tuning. The man is a god and helped me to not blow my car up after multiple engine mods. :party0030: |
I've done this and my KW C38 kit has been happy as a clam! |
Hey guys, looking to see if I can get any assistance. Just installed a low miles c38 kit I bought from a member. Install was fine and it runs well. My tuner is using OFT to tune it on 91 since I can't afford ecutek at the moment and still running stock injectors, clutch etc. We're having problems where this c38 will want to go beyond 12lbs before redline so it bucks. I have the datazap here:
https://datazap.me/u/sawvyeej86gmail...og=0&data=1-10 What size pulley does the standard c38 come with? What size is recommended to stay at 10lbs? Would like to hear some replies before I take her off again. Thanks! |
Standard C28 rev 2 and rev 3 are 95mm, the first revision is 90 I think... Not sure what is going to keep it at 10psi, not sure if there's a larger pulley :O
Idler Bolt
2 Attachment(s)
Supercharger and belt still running good. But having an issue with the Idler pulley backing out. The Idler pulley bolt snapped. I replaced it with a longer Bolt, Placed white out on the tip of the bolt and test drove it for about 5 mins. I noticed that the bolt again backed it self out slightly. How tight is tight with this idler bolt and and tips on keeping it tight? Like everyone else, this would be the perfect kit if the tensioner was automatic lmao
^not sure if you already fixed it but the threads on that part look pretty messed up. That might be the reason why it backs out under load. The longer bolt might be bottoming out and not holding the idler pully tightly.
1. check the threads. 2. get the correct bolt length. Like most people, I ruined my first C30 due to the improper belt tension instructions and also had the pulley fall off because I didn't use lock-tite. After leaving the belt on the looser side of things, I have had no issues in hot or cold weather. Easy $2000 mistake. |
| All times are GMT -4. The time now is 10:19 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
